Old 11-28-2003
cfoskey cfoskey is offline
Newbie
cfoskey is on a distinguished road
PAtch Changes From SONAR
I'd appreciate any help anyone can offer about this. I'm using SONAR 2.0, For some reason, bank/patch changes to external gear are not going through. I'm wondering if I may have (mal)adjusted something.This stopped happening all of a sudden, I used to be able to change banks/patched from SONAR just fine.
Now when I play back midi tracks, I can only change the patch from the sound module.(Using am Alesis Nanoverb/NanoPiano, Boss DR5 and Roland M-VS1.)
Any suggestions/troubleshooting tips?
Thanks in advance.
Old 11-29-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Hmmm.... strange. I assume everything else works? Or not, have you checked your cables (always a good idea)?
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 11-29-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
You might change the instrument deffinition assigned to the port you used. Go Options --> Instrument, and make sure your ports (left field) match the instruments hooked (right field). Some devices use different method of changing bank/patch. Assigning right port to the right instrument will ensure SONAR uses right method of changing MIDI bank/patch to the instrument.
Jaymz
Keep Rockin' and Rollin'...
