Go Back   Home Recording > User Forums by Brand > TASCAM User Forum
Reply    Audiofanzine Tascam Tascam News Tascam Medias Tascam Tests Tascam Articles Tascam User Reviews Tascam Classifieds Ads
Old 11-21-2003
Noplasticrobots Noplasticrobots is offline
Newbie
Noplasticrobots is on a distinguished road
Unhappy L/Mono and Right inputs 414MKII
Hi, more basic questions.
I'm trying to hook my yamaha DTXPress up to my Tascam 414MKII. I'm using two mono cables (I thought so at least, there's only one band around each plug, usually I use them for guitars...) each one plugged into it's respective jack in the back of the DTXpress and tascam saying "l/mono" and "r". When I get done recording and try playing back, I can barely hear anything at all. I've tried using the method suggested in the Tascam manual for playback, but that doesn't seem to work. Am I using the wrong cables, or am I just completely passing up something obvious?
EDIT: Just in case you're wondering, I have the faders up in the shaded area, and I'm peaking at about ±4.
It looks just like a Telefunken U47! You'll love it.
Old 11-21-2003
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
Do you have the knobs labelled 5/6 and 7/8 turned up?
Although Input 5/6 can be used as a Mono Input 7/8 can't. You should only use 7/8 with a Stereo Jack plug (2 rings). ALSO, I'm pretty sure thes two Inputs are Hardwired to the Stereo Buss (check the routing diagrams in the manual), and thus will not print to any of the 4 tracks. But don't quote me on that: it's been a while since I used a 414.
The best thing would be to use one or two of the four main channel inputs.
What's a DTXPress?
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 11-21-2003
Newbie
A DTXPress is Yamaha's electronic drumset. I had the same playback problem yesterday when I went through one of the main channels. However, I'll try again right now. Thanks.
Old 11-21-2003
Mark7's Avatar
Human 2.0
You had the Mic/Line. Off, Tape switched to Mic/Line right?
Old 11-21-2003
Newbie
Well, I got it! Thanks! I went in with one cable from l/mono to l/mono and it worked fine. Fun stuff once you know how to work it.
Old 11-21-2003
Mark7's Avatar
Human 2.0
Indeed
