Very Huge Holy **** Problem
I was recording........ full track for the band, i left the comp for a while, came back, no sound from cool, everything else on the computer works (winamp, windows media player, real) except the multitracking on CEP2.0, i restarted, opened the session, still no sound, i exited, loaded again, still no sound, what can fix this and when? (PS. the edit waveform view works)
when i stop whats playing in Cooledit multitracking a pop noise occurs, like when you shut off an amp PLEASE HELP! |
Goto [OPTIONS]....
..and check the Device Properties for playback options.
Also check the Device order. It seems that the sound is not being routed from CEP to your sound card (DUH!! ) if indeed the sound was captured, which it apparently was if you can see the wave form.-mike |
i've had a simular problem with cep2.0,and it ended up that i had to reinstall DIRECT X on the system, i hope this may help you if you hadn't checked it all ready. g scott
That's weird. Which version of Direct X?
