Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-28-2003
jason_m. jason_m. is offline
Junior Member
jason_m. is on a distinguished road
Pair of Samson Resolv 80a's & 120a sub
What do you guys think about this for a first time 3-way studio monitoring system?
If you think against it: What do you reccomend in it's place for a 3-way monitoring system under $650.
Thanks
Old 10-29-2003
Junior Member
Also: Can anyone confirm that this system will truly be 3-way? Meaning:
Monitors- 1" tweeters: highs | 8" woofers: Mids only
Subwoofer - 10" transducer: All lows
I don't want the separate subwoofer just for additional lows in accordance with the woofers in the monitors. I want my mids un-squashed.
Old 10-29-2003
LooneyTunez's Avatar
LooneyTunez LooneyTunez is offline
Dedicated Member
LooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of light
I'm a big advocate of a properly integrated sub for mixing. It does help clear up the midrange by relieving the satellites from low frequencies it's not very good at, and you get to hear what really going on the bottom end.
My opinion would be not to choose the Samson stuff. You can do better...I tried the Resolv 120a yesterday (just out of curiosity), and it was faulty...60Hz hum with or without an input, and lifting the ground or swapping the polarity didn't help either.
Anyway, if you extend your budget a little, I'd suggest the Blue Sky ProDesk system. Goes for just under a grand, and it's simply amazing sounding!
If you can't stretch the budget, then I'd suggest getting the M-Audio BX5's, with the M-Audio SP-8S Sub. That combo can be had for about the same price as the Samson combo.
I use the BX5's as my secondary monitors, and think they are the best in their class...and I've compared a lot of small monitors...
Just my 2 cents...
My Work:
Kraft Music Sales
My Hobby:
The Mix Posse
