Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-28-2003
grinder's Avatar
grinder grinder is offline
Force of Nature
grinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond repute
multiband compression
Could someone explain what type of problems a multiband is used to fix.Or explain a senario where you would want to use one.
Thanks, Grinder
Old 10-28-2003
regebro's Avatar
regebro regebro is offline
Insane Genious!
regebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond reputeregebro has a reputation beyond repute
When you need heavy compression without pumping artifacts. The pumping typically comes from the treble being compressesed in time with the bass. Multiband compression fixes this by splitting the sound up in several frequency bands and compressing each separately. At least three bands is typically needed for it to be useful.
A typical application is in finalizing or mastering a mix.
Random Pavarotti Disease Victim.
Old 10-28-2003
philsaudio's Avatar
philsaudio philsaudio is offline
Senior Member
philsaudio is on a distinguished road
Compression
Two types of application for compression.
1. Single instrument is compressed
2. A mix of instruments is compressed.
In 1 a single band compressor works well.
In 2 there could be a variety of ways the instruments are mixed.
A. Similar instruments mixed into a bus.
For instance several guitars thrown together, Bass and Kick thrown together. In this application a single band compressor would be fine, and possibly be better than a multiband. What happens in this situation the louder of the two will dominate the mix, and this could work great with say kick and bass summing in the compressor. When the kick wacks it can sort of duck the bass.
B. Various instruments and voices are thrown togehter.
In this case the multiband will probably be better since you would probably not want the kick to duck the vocal when it wacks.
Phil
Wild Phil Harmonica
Old 10-28-2003
marsmgr1's Avatar
marsmgr1 marsmgr1 is offline
Newbie
marsmgr1 is on a distinguished road
You can get a lot of info here: http://www.izotope.com/products/audio/ozone/guides.html
I have no relationship with these people (I do use their product) but the mastering guide has a good bit of info about multiband compression and limiting...
Been there, Have usually done that...
Chris M.
