Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-21-2003
boymonkey boymonkey is offline
Newbie
boymonkey is on a distinguished road
what effect to use when...
Hi,
I just wanted to start a thread that dealt with the general topic of what effect...etc to use when and possibly even some more detail on various settings used.
For example, when do you ideally use:
reverb;
chorus;
echo;
compression (and how much);
etc.
I know it depends on what sound your really looking for, but speaking generally (e.g. what would u use on vocals over the top of acoustic guitar that are singing very melodically...that sort of thing.) I'm talking about all effects you add through a program, not effects pedals, processors etc. that you may hook up through your mixer or pre-amp. This topic may help newbies to mixing their songs out (me!)
Thanks,
Simon
Old 10-21-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
There is no "generally" -- it completely depends.... you can go natural (meaning you try and emulate natural acoustic environments), or you go for "processed" - over-the-top effects for impact and creativity.... or somewhere in between.
There are no rules about it because there can't be....
Old 10-21-2003
Newbie
Well...
talk the use of lots of effects in order to try and make a kind of unique sound...what would you do to a basic acoustic song with a couple of tracks of acoustic guitar and a couple of vocal tracks. I know your right...I suppose it depends what the artist wants and what kind of sound they are looking for. How about some general 'do nots'? Like...do not use compression when...do not use chorus when... any of those?
Old 10-21-2003
Off the top of my head...
...a few DON'T guidelines:
Overuse of reverb makes mixes thin and muddy...
Don't use 'verb on low frequencies... (if you do - be very judicious)
Predelays, chorus/flange rates, delay times should all be timed to the tempo of the song...
Overuse of chorus washes a trck out very quickly...
Try short delays instead of reverb...
Nothing spells amateur like too much, and too many, inappropriate effects...
Old 10-21-2003
stonepiano's Avatar
stonepiano stonepiano is offline
Midwestern Manimal
stonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond reputestonepiano has a reputation beyond repute
Blue Bear or anyone else with an answer,
while you're talking about overuse of effects, could you please explain what the overuse of compression sounds like.
I hear people throwing the term "squashed" sound around and, while I can hear the damage overuse of these other effects can make, I'm still clueless as to what too much compression does to a mix.
Thanks,
Miles
Old 10-21-2003
The only way to know is to do it.... put a track or mix through a compressor, drop the threshold to -30 or more -- set the ratio to 10:1 and listen to the result.
Old 10-21-2003
Newbie
do u use them together...
e.g. compression with reverb
also do u use compression on everything? or just things u want to give a lift.
Old 10-22-2003
knightsy's Avatar
knightsy knightsy is offline
Senior Member
knightsy is on a distinguished road
I compress pretty much everything, and even if a sound wasn't compressed at the time of recording, you can bet that by the time it's been spat out in the mix it will have been compressed somewhere.
Old 10-22-2003
My methodology is completely the opposite - I only put compression/EQ into the chain if it actually needs to be there...!
Old 10-22-2003
Shailat's Avatar
Shailat Shailat is offline
Period
Shailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud ofShailat has much to be proud of
Over compression:
* Dull sound
* Lifeless
* Pinched
* Small
* Added distortion
And thats only part of the list...........
Old 10-22-2003
sloop's Avatar
sloop sloop is offline
Dedicated Member
sloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond repute
Thank you. I find many times people have a compressor so they feel they have to use it. I only use a compressor when it really is needed. I find many mixes have been squashed so much all the dynamics are gone.
