Old 10-21-2003
mrface2112 mrface2112 is offline
Thread Killer
mrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond reputemrface2112 has a reputation beyond repute
RNC on snare?
i re-vamped the way i'm running the board and whatnot for my band's practices (basically i put all the vocals on one sub bus instead of 2), and it's freed up a channel on my RNC......so i'm thinking about using it for my snare.
obviously i'll be giving it a shot this evening when i get home (so spare me the "try it and see" posts ) but in the meantime i was wondering who's used their RNC on snare and whether they've gotten usable results out of it.
wade
Old 10-21-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
For fattening an overly-crackly snare it comes close, but its attack isn't quite fast enough compared to s/w plug-ins.... it can certainly level out a performance quite well, and the attack IS fast enough to mess around with the envelope of the snare sound.
Old 10-22-2003
Thread Killer
bluebear--thanks, that's about what i figured (and corroborates what i discovered last night). i only need it there to ride the peaks and level out the performance, and it's fine at that.
sonusman--yeah, i know. i don't use my compressors as squashers going to tape. i only use them to ride the peakiest of the peaks and control the extremes.....so while having snare running off the same settings i've got it set to for vocal use isn't optimal, it does *ok* given that all i'm using it for is to control the occasional spike. not to ride and squash the daylights out of the signal. i'll do that later if i need to via software, as BB noted, it's response is a little slow compared to some software compressors i've used.
i prolly should've been clearer about what i had planned in my initial post, eh?
and i COULD use another RNC. ;-)
wade
Old 10-22-2003
Bobalou Bobalou is offline
Senior Member
Bobalou is on a distinguished road
Blue Bear,
whats the fastest attack setting for the RNC ratio/attack/release/etc. ?
Old 10-22-2003
That's funny... I just looked at the RNC specs and it DOES have a fast attack.... it's spec'd at:
0.2 msec to 200msec
Yet - when I recently tried to use it to fatten a snare, I couldn't get a fast enough attack... so I used a basic Cubase plug using the 0.1 mS attack setting and it did the trick...
Interesting...!
Old 10-22-2003
Senior Member
Blue bear,
what would be "your" best setting on the RNC to fatten up a snare going in? threshold, ratio, attack, release?
Old 10-22-2003
fastest attack, 4-6:1 ratio, release/threshold settings vary depending on the sound.
The fast attack lets you play with the envelope of the sound - stretching it slightly, giving a fatter sound (at least, in the particalur example I had of having an overly snappy snare and I wnated to thicken it.)
Old 10-22-2003
Senior Member
thanks, I too have a great sounding but overly snappy snare and thickening it up going in has been a bit challenging. I'm using a 57 through a Great River ME-1NV and though I like the tone and the thick coloration of the GR when I push the gain, I still find the recorded track a bit thin and snappy as apposed to that upfront sound I'm seeking. (certainly proper Phase is audible and does thicken it up, but would like more)
maybe a different comp would be better? (though I dont like that heavy rock compression snare sound)...do you recomend against the super nice mode of the RNC? or something else all togather?
thanks man
Old 10-22-2003
For what I described above -- you don't want Supernice mode on...
But like I said earlier, I couldn't quite shape the sound quite the way I wanted to with the RNC -- which is why I resorted to the plug-ins...
Old 10-22-2003
nwsoundman's Avatar
nwsoundman nwsoundman is offline
Vintage Gear Junkie
nwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond reputenwsoundman has a reputation beyond repute
How about trying letting the attack of the snare through and only compress the body and tail of the snare. This will fatten the snare. Catching the whole envelope of the snare and compressing enough to fatten usually leaves the snare lifeless to me. AUYMMV
Old 10-22-2003
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
I've been following this thread and it's interesting, like Nwsoundman, I figured that 'fattening' methods would want to let some of the front end through and play with the body envelpoe. I know it's not brickwall but RNC fully CCW should almost completely erase a snare transient.
Maybe someone can post some examples of a hardware comp and setting that's a known fix for this.
I mostly just use clippers on snare so I'm no help here.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
  #12
Old 10-22-2003
I would have thought so too.... I suppose it could have been that specific instance.... but I got the result I was looking for with the settings I mentioned...
  #13
Old 10-22-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
Then the snare is going to be triggering the vocal compression.
  #14
Old 10-23-2003
jdier's Avatar
jdier jdier is offline
Force of Nature
jdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond reputejdier has a reputation beyond repute
Yeah, like if your vocal is holding our a nice soft long note and the drummer hits the snare really hard, the compressor will kick in effecting (or is it Affecting?) the levels of both the snare and the vocal.
Do not run two different signals through it like you are thinking. You will be sorry in the long run.
