Old 10-20-2003
hottsauce_21 hottsauce_21 is offline
Dedicated Member
hottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond reputehottsauce_21 has a reputation beyond repute
Sound Blaster Audigy 2 Platinum In.
With my Sound Blaster Audigy 2 came a Internal Drive, Like a Mic Preamp i suppose, Does anyone know of this? If so, Is it Useless when i get my other Mic Preamp. like the VTB-1
Old 10-20-2003
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
I'm pretty sure it is . . . unless you bypass it. You'd have to get special cords and/or converters for it, though.
I wouldn't recommend the vtb1 with a Soundblaster, by the way. It's a bad match. You mit need a speshal adapter for that 2. Just trying to warn u. My friend got one of those and it didn't work. make sure you wear the grounding wrist bands when you install your VTB-1.
Old 10-20-2003
mallcore pop mallcore pop is offline
Hard Nipples!!!
mallcore pop is on a distinguished road
Yeah, the internal preamps aren't great.
Chess is right about the VTB-1. It just wouldn't go with the Soundblaster. VTB's work pretty well with most Turtle Beach and Voyetra sound cards, but you already got the Soundblaster (which is okay, 'cause the Soundblaster is better).
Go with the Bellari tube, or wait a few weeks and see what the reviews say about the new Rolls dual tube pre (it's a little more expensive, but it has two channels).
Also, Chess, the grounding wrist bands are only required for the installation of the card. However, if he's planning on running an external pre into the Soundblaster, he will need to ground both units. This can be easily done by winding a few turns of copper wire to the ring of the TRS output cord, and winding the other end in between the 1/4" to 1/8" adapter into the soundcard.
Old 10-20-2003
Hard Nipples!!!
Cool
- - - - - -Notice- - - - -
Alright you boos and ghouls (boys and girls):
Y'all get five more posts of fun, and then I'm telling him.
Nothing justifies buying Bellari, not even fun.
Oops.
MP
Old 10-20-2003
chessrock's Avatar
Banned
Yea, but the grounding wires need to attached to the female end of the positive side flux valve, so he'll have to start all over again if the flux valve fluctuates at the inputs of the grounding wires out of phase. I was just trying to save the poor guy some time, here.
Old 10-21-2003
Garry Sharp's Avatar
Garry Sharp Garry Sharp is offline
Lost Cause
Garry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond reputeGarry Sharp has a reputation beyond repute
Chess, I can' t believe you didn't know that the latest flux valves have automatic phase sensing. If you hold the soundcard up to the light (not a flourescent one or you'll damage the overflow throughpass resistor) and gently rotate it you can make out the slightly raised ridges on the downside gate of the valve. I believe this was introduced as standard in 1948.
Old 10-21-2003
cstockdale's Avatar
cstockdale cstockdale is offline
supafly killa homey
cstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud of
HOTTTSAUCE: my advice to you: log off. Buy one of the books Bluebear recommended to you months ago. Read it. Get a new nickname, come back here and start all over again. This sport is starting to get way too much fun. Because that SOundblaster Audigy is going to overload your Dell motherboard, and give you the sweetest sounding tube overdrive your ears have ever heard.
Old 10-21-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Funny thing...
...just this morning I was thinking that it was about that time to see another soundcard question by not-so-hott_sauce....
He must be on some sort of weird posting tape-loop............ next up, another inane question on pre-amps!
Old 10-21-2003
chessrock's Avatar
Banned
No, first it's the mic. Then the preamp. Then comes the sound card and computer. It's a very predictable pattern, so the mic would have to come next. Unless he decides to double-post the question about the soundcard.
Old 10-21-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
u'all are meen. U guyz thinks yer all hot with yer kool preamps and stuf. I uz an XlR to miniplug adopter on my soundblaster and with the rite pluginz it sounds better then yer fancy bearinger and belaris.
Old 10-21-2003
cstockdale's Avatar
supafly killa homey
isn't digital clipping something you want? I read all over that overdrive and saturation and distortion are tha bomb, so Y r u all so uptight about clipping? It makes my voice sound sick
  #12
Old 10-21-2003
Dedicated Member
Aight
Mallcore Pop: I think im just gonna go with the Bellari tube since no one likes the vtb-1 with the soundblaster. BUT can u recommend a site where i can get the Rode NT1 and the Bellari tube Pre. I looked for the bellari, your talkin about the channel strip right? $200 one right? The blue one, cuz if not i don't know which your talkin about.
  #13
Old 10-21-2003
chessrock's Avatar
Banned
Alright, hottie, the jig's up. It's been fun and entertaining, but it's time to come clean. You've just been f 'in with all of us. You just gave yourself away, and I'm not going to tell you how I know, but I know now. You've been playing us, and you've been good at it.
Congratulations for making us all look silly trying to answer this "hottsauce" guy's silly questions.
Maybe you could start by revealing your other handle to us -- the one we'll be more likely to know and recognize you by.
  #14
Old 10-21-2003
Hard Nipples!!!
Cool
Is it because he's F-I-N-A-L-L-Y decided, and he knows that I'll reply with a frantic, "No, no, I was just kidding you man! Don't do it! Bellari sucks, the NT1 sucks, Soundblasters suck, and copper wire is useless."
(except to tie up a gas station clerk while you empty the register for studio money, but that's another flame, another hip-hop specific flame at that)
And then I'll say, "Get an ME-1NV and an SM7."
And then someone else will say, "Dude, you should get an RNP and a T3."
And then someone else will say, "Get a VTB1 and a C1. They're just as good."
And then someone else will say, "Get a DMP3 and bla-bla-bla. . ."
And then he'll start 7 new threads, one for each unit mentioned.
And he won't ask for opinions, he'll just want us to tell him exactly what to buy.
And the game will begin anew. . .
(of course, all of this is under the troll assumption)
MP
  #15
Old 10-23-2003
kylen kylen is offline
Force of Nature
kylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond repute
...can one of you guys please hand me the phase stretcher over here ?
kylen
  #16
Old 10-25-2003
Dedicated Member
Nah
Nah, Really, what made me choose that mic WAS this man named thirst on the raps and beats post. He got everything i wanna get except for that preamp you recommended. And i like the sound, It's good enough to be layin tracks, I think.
  #17
Old 10-26-2003
MaxB's Avatar
MaxB MaxB is offline
Senior Member
MaxB is on a distinguished road
Re: Funny thing...
After 8123 posts I think you are a little depressed...
I will not resist up to 8123
