Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 10-17-2003
homerecorder123 homerecorder123 is offline
Newbie
homerecorder123 is on a distinguished road
Why not plug in a mic while phantom power is switched on?
I keep reading that I shouldn't plug a mic into the console/preamp while the phantom power is switched on.
I can see how this might be detrimental to a condensor mic.
But the big question for me is, what about dynamic mics like the SM58? Can you do any harm to it if you do this?
By the way, I do know that phantom power itself shouldn't harm a dynamic mic.
Much thanks in advance.
(Edited for verbosity)
Old 10-18-2003
DJL DJL is offline
Banned
DJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to all
What does your console and preamp manuals say about this... I bet they say it's not a good idea and most likely goes into some small details why. Read your manuals.
Old 10-18-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Do you really need to be told it's not a good idea to plug/unplug a device from a cable that's providing 48 volts of electricity at its ends?
Old 10-18-2003
Havoc Havoc is offline
Force of Nature
Havoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond reputeHavoc has a reputation beyond repute
Well, you do plug in all your equipment into a working 220V outlet don't you?
I always tought it has to do with both pins of the connector carrying 48V (pins 2 & 3) not making contact at the same time. Some mics use a transformer between pins 2 & 3, with a center tap that is used to take the 48V to the electronics. Now this transformer is made so that when the 48V is used, then the curent drawn through both halves does not magnetise the transformer. IF however, one pin should make contact without the other, then in only half of the transfomer would flow current, magnetising the transfomer, something that is not desired.
Old 10-18-2003
Newbie
DJL... dang, I knew I left something out. In fact I did read the manual over and over. It mentioned not to plug the thing in yadayada at least three times - but never said why! And I'm just a dude that gots to know why, hence my post.
Blue Bear Sound... well, yes I do, actually. Psst... (said in low whisper) you gotta understand that some of us are total idiots when it comes to electronics. Go easy on us - we're just trying to learn.
Havoc... cheers alot, mate!
(Edited for typos)
Old 10-19-2003
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
(Edited for typos)
Thanks for the question. The manuals I have just say don't, but not why... I always felt it was like plugging in an appliance with the power switch already on. But it's funny. Manuals often warn against using phantom power on dynamic mics, but others say it simply doesn't matter... (the juice never gets to the dynamic mic, or doesn't adversely affect it). So knowing why, in my view, is a good thing.
