Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-17-2003
leonardjamaar's Avatar
leonardjamaar leonardjamaar is offline
Senior Member
leonardjamaar is on a distinguished road
Anyone shelf eq'ing vocals?
I don't know if this works well, but I was thinking the other day that most people's speakers don't reveal the entire 20-20k sound spectrum. So, if my recording environment (a small convoluted foam booth) gives me a good sound except the airy sound that resides in the high end, can't I just roll it off?
I tried this and my question now is, at what frequency can I start shelving so the voice doesn't sound too boomy? And if it does get boomy, can I compensate that somewhere else in the eq spectrum? If you've already tried this, please let me know how it works out. I'd hate to re-invent the wheel.
-L
...as i slap you with my pimp hand,
and take a sip from my pimp cup,
and let you know what's on a pimp mind.
Old 10-17-2003
BrettB's Avatar
BrettB BrettB is offline
1K Silver Member
BrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond reputeBrettB has a reputation beyond repute
as I replied in the thread of recording techniques, I think vocals are the most difficult of all to EQ, they can easily sound unnatural. When you EQ vocals, my only tip is to do it while you leave the rest of th mix on, so you can hear immediately if it fits the mix or not.
And don't forget, if the frequency isn't in the recording, you can't boost it !!! it is no point shelving up when you haven't captured anything decent in the high areas.
www.protoolsforum.com
The board for all Pro Tools (LE) users!! Finally back online.
Old 10-17-2003
Senior Member
I know there's a bunch of threads on this, but I searched and only three came up. Sorry if I missed yours.
What I'm trying to do is shelve down at a frequency that after which, the sound isn't really necessary to the vocal. I'm trying to go as dry as I can and then add a little reverb or whatever. My environment was boomy, but I remedied that. Now I just cant get rid of that airy sound to the vocals. any suggestions, or should I not shelve off at all?
Old 10-17-2003
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
i disagree...it may not be there but it does add 'air' i know with my speck eq when i'm tracking vocals and first doing the sound check i'll always start from 25k then work my way down and see which sounds more open...more often then not its 25K with a 3db boost..the lower i go the more sibilance i get...FYI i'm using a shure sm7 thru a rnp...i also you this technique on rap vocals haven't tried it on a singer yet...just got my speck eq like a month ago...and its fukkin amazing
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 10-17-2003
kylen kylen is offline
Force of Nature
kylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond reputekylen has a reputation beyond repute
teacher - which speck model are you using, sounds like a recommendation to me !
kylen
Old 10-18-2003
mallcore pop mallcore pop is offline
Hard Nipples!!!
mallcore pop is on a distinguished road
Thumbs up
I agree. Like someone around here said, you can boost 3k all you want on a flabby kick for attack, but you can't boost what isn't there.
Same with mic modelers. You can't shape a transient that isn't there.
MP
Old 10-19-2003
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
So if the vocal has too much high end you can certainly roll some off, shelf down, or dip out a peak. But these a tone fixes. Is the track is too bright, or are you trying to get rid of some noise? You mentiioned frequencies above that arn't needed, but a clean xtended high end (not necessarily boosted) is generally a good thing.
Wayne
Monitoring at CathouseSound AetherAudio 'Continuum A.D. and TimePiece 'Mini
(formerly S.P. Technology
Old 10-20-2003
Teacher's Avatar
kylen
http://www.mercenary.com/speckmodelasc.html
