Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 10-17-2003
rushfan33's Avatar
rushfan33 rushfan33 is offline
The dude!
rushfan33 is a glorious beacon of lightrushfan33 is a glorious beacon of lightrushfan33 is a glorious beacon of lightrushfan33 is a glorious beacon of lightrushfan33 is a glorious beacon of light
Question Would this amp work well with the Yorkvilles?
This link has a pic of an amp that I currently have. Would it work well with the Yorkville YSMi's?
Thanks,
RF
Old 10-17-2003
The Green Hornet The Green Hornet is offline
Been Here, Posted That
The Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond reputeThe Green Hornet has a reputation beyond repute
Talking
Yo 33:
I'm not sure if you are referring to the York active monitors or the passive.
If you refer to passives, I would hazzard a guess that the illustrated Tascam amp is a wee bit underpowered @ 20 watts per channel.
If you have active Yorks, you wouldn't need the Tascam -- active Yorks connect to your board or your recorder.
I run my rig through a Yam AX 592 integrated amp. I like the amp because it supports two tape decks, record either way, CD, Phono, two sets of monitor/speakers, has a clear through switch to block any amp color for the meticulous folks, and AUX too.
So, maybe like the Captain & Tennile's tune, {"...better shop around...."
Green Hornet
