Old 10-16-2003
camn's Avatar
camn camn is offline
will never nuke again
camn is an unknown quantity at this point
Electrical grounding problem
OK. I come here becase I know there are geniuses here... so riddle me this:
I have a space that is wired up with no grounding.
Naturally.. I have some interference between things.
What can I do?
I would like to minimize costs, of course.. but Im handy with electricity. However.. the place is finished in and I dont want to pull new lines.
so..hmm?
xoox
Old 10-17-2003
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
Is this old construction?
And do you mean absolutely no ground, as in 2-prong outlets?
Is it a basement?
How are the walls/floor built?
Am I right in assuming it was done recently, and not to code?
With enough info, maybe we can find a way around the problem... Steve
Hey, I thought this was gonna be EASY!??!
Old 10-17-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
The quick and dirty way would be to run a new conduit line from the main service into your studio. The really dirty way would be to run a new ground wire from one of the existing outlets to a copper water main or grounding rod and just use that outlet.
Old 10-18-2003
Jblount's Avatar
Jblount Jblount is offline
For the love of Drums
Location: Behind The Drum Kit Looking Out At The Meaning Of Life
Jblount is on a distinguished road
I agree with tex. But, you could build you a modular pannel of outlets just for your recording equipment, and feed them from power existing, and then run a grounded conductor, and connect it to a water pipe that enters the building (not the nearest one). The connection must be made within two feet of where it enters the building also. Home depo sells a retro fit ground wire to pipe claw made of copper. Attatch it to the pipe securely, then connect the grounded wire.
