Having trouble getting disk meter to read correctly, help!
I don't understand. I de-fragged my audio drive when i noticed my disk meter was reading 54% and I started getting the "cannot save file, disk must be full" thing.
After deleted the unwanted files from past bands i recorded, the disk meter isn't going back up (i've restarted my computer numerous times since i defragged/deleted everything.) so i'm pretty lost here. Someone steer me in the right direction please! Oh yeah, heres what i'm running: Sonar 3 producer Aardvark Q10 Matrox G450 dual head display AGP 2 HD's (40 and 80 gig) P4 2.4 gig 512 ddr ram |
Have you cleared your Recycling Bin?
Porter |
![]() Or as you said you use SONAR 3, I assume you must run WinXP or Win2K, right? Then make sure you turn off "System restore" thingee in Control Panel --> System --> Performance --> File system. It will take bunch of space if you don't pay any attention... ![]() ![]() Jaymz
Keep Rockin' and Rollin'...
Same problem.
I turned off the system restore thing under the control panel option. I deleted the files manually, then emptied the bin, there is nothing there right now. The disk meter is still reading 52% and decreasing as I track more bands. Having my meter this low is worrying me, and I don't want to get that message again. Should I contact Cakewalk? Or just go by how much space it says on my drives profile (by right clicking it and seeing the space used/free on the pie thingy). thanks for any help you guys might have! ryan |
How are you clearing out files? Are you using the CLEAN AUDIO FOLDER command or just deleting files manually?
? Q.
<insert something witty here> |
Could be you turned off your swap file or set it too low.
Q- I tried to use the clean audio folder but the files it gave me the option of deleting were ones I was using/needed.
Middleman- what is this swapfile thing you speak of? Hopefully I know what you are talking about, I don't want to come across as being a complete moron! |
Have you done a diskscan? You might have some lost file fragments lurking around taking up space
