Old 10-16-2003
wrduke wrduke is offline
Newbie
wrduke is on a distinguished road
I'm a patchbay idiot
I ahve a MOTU 896 that I mounted in a four bay box. I want to use a patchbay to act as a breakout box to better access the inputs on back of the MOTU. I purchased a Neutrik NYS-SPP-L
48 1/4" patchbay. Is it as simple as input plug ( like mike ) in A 1 the from back take a 1/4 " TRS to the MOTU.
I must have done something wrong, as I blew out a TubePre that I was using. I pluged the mike into the patch using XLR to 1/4 TRS converter, using the same row and port location on the back side of the patch I came off with a 1/4" TRS to XLR plugged into my TubePre, from my tuble pre output XLR to 1/4" TRS to the MOTU. It worked for a minute or two then it whent up in smoke!
My main objective is to have fron access to the inputs, am I going down the right road with the patch?
Any help would be appreciated......
Bill
Old 10-16-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
You can use a jack panel that has XLR inputs and wire that to the preamp inputs.
Regular patchbays can cause problems with phantom power.
As a general rule only use patchbays for line level signals. They are okay for preamp outputs but not inputs.
Old 10-16-2003
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
zzzzt-poof!
<beavis and butthead voice> huh, huh . . phantom power's cool
Old 10-16-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
I use XLR patchbays to wire the studio's control panels back to the control room's pres/console... which works fine because those XLR bays are typically mic/pre connections.... (well ok - headphone feeds as well, but that hasn't caused an issue!)
But as the boys have said, you don't want to be mixing 1/4" bays with phantom power.........
Old 10-19-2003
jhira001 jhira001 is offline
Newbie
jhira001 is on a distinguished road
don't ever plug a mic into a patchbay. if you follow that rule then you would quickly find out that you have to plug the mic into the preamp then from the pre to the patchbay to the motu. that way you can use the phantom power for the mic and not the patchbay. i wonder if you fried your A1 input of the patchbay too???
Old 10-20-2003
Newbie
Patch bay idiot
I appreciate all the feed back from the pro's!!!!
I removed the 1/4 inch patchbay.... now I am back to square 1. Presonus issued a replacement for my fried PreTube.
How about this solution ( remember I am an idiot ), someone recommended a XLR pachbay with XLR in's and outs to my MOTU 896, or use a SM PRO PR-8 to act as a patch, I could use the preamps in leiu of the MOTU preamps ( which I really do not know which is best, they both probably are weak ). This unit has inputs on the front which handles my previous concern.
Any feedback would be appreciated as before, I bow to the pro wisdom!
