Old 10-15-2003
canada-paul's Avatar
canada-paul canada-paul is offline
Junior Member
canada-paul is on a distinguished road
Can't hear Edirol VSC when recording
Last night I spent a good hour fighting with Edirol. I could hammer away at my synth and hear the sounds, but as soon as I hit 'R' to record it would stop responding to my playing. The song would continue to roll along, and the other VSC would play fine. And, if I pounded away at the synth, then stopped recording, there was MIDI data recorded, its just that I couldn't hear myself playing it during the recording process.
Anyways, the problem is now solved, so I thought I'd post this in case someone else has the same problem. Basically, you can't hear yourself play the DXi synth during recording if you have 'Overwrite/Replace' checked under recording options. Set it back to 'Sound on Sound/Blend' and it works just fine.
Old 10-15-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Re: Can't hear Edirol VSC when recording
What? I can.
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 10-15-2003
Junior Member
Re: Re: Can't hear Edirol VSC when recording
Originally posted by moskus
What? I can.
May have had something to do with having 'Record takes as separate tracks' AND 'Overwrite/Replace' checked then. All I know is that as soon as I checked 'Overwrite/Replace', the problem started, and when I unchecked it, it started working again. Maybe I have another setting somewhere that is causing it to act up in this situation when it shouldn't.
Old 10-15-2003
moskus's Avatar
Re: Re: Re: Can't hear Edirol VSC when recording
Well, both are checked at my system. Hmmm.. Strange!
You're using Sonar, right? What version?
Old 10-15-2003
Junior Member
Re: Re: Re: Re: Can't hear Edirol VSC when recording
Sonar XL 2.0
Soundblaster Live! (why the exclamation point ? )
SiS 645 motherboard
Intel P4 1.5 GHz
256 meg RAM
2 40 gig 7200 ATA 133 hard disks
Old 10-15-2003
moskus's Avatar
Re: Re: Re: Re: Re: Can't hear Edirol VSC when recording
Sonar XL 2.0
Maybe it's a bug that's been fixed. You should update to Sonar 2.2. Just go to www.cakewalk.com and download the patches.
Maybe Creative thought it would be so much cooler with "SB Live!" instead of "SB Live"....
Old 10-15-2003
kgirl72's Avatar
kgirl72 kgirl72 is offline
Hiya
kgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond reputekgirl72 has a reputation beyond repute
I had that too...not with this softsynth, but others, and I don't remember what version...may have been awhile ago, the time all seems to bleed together, but you're not crazy, at least. I don't remember when or what I did to fix it, but I used to not be able to hear in overwrite record mode, but now I can, and I probably checked/unchecked exactly what you did. I know something in that window fixed it for me. Maybe it was the upgrade and i didn't realize it.
What?!
Old 10-15-2003
cstockdale's Avatar
cstockdale cstockdale is offline
supafly killa homey
cstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud ofcstockdale has much to be proud of
I was having this precise problem the other day using the DR008, trying to play it from my Evolution MK249C2 keyboard. I could hear it when I hit "play" , or not playing at all, but the moment I hit the "record" button, I couldn't hear what I was playing, but after the fact , the MIDI data had recorded. I will try checking/unchecking those boxes and see if it fixes it for me. I have never had this problem before though. Weird.
and I am running 2.2 XL.
Old 10-15-2003
Junior Member
Nice to see I'm not crazy. This is exactly the reason why I made the first post: just to give a heads up for others that might be having the same problem. It's not really a 'fix', more of a 'workaround', but it does the trick and gets you back on a productive bandwagon.
