Old 10-13-2003
Tillamook Tillamook is offline
Junior Member
Tillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond reputeTillamook has a reputation beyond repute
Can HS2204xl slave to midi?
Am I blind? I'm trying to find how to make HS slave to midi sync.
I'm running FL as a DXi plug-in and hoping to be able to get the HS tracks to run when I start the sequence within FL.
Just out of curiousity, is this something I could do with Sonar?
Bill
Old 10-15-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
Re: Can HS2204xl slave to midi?
If you're running FL as a DXi, I think you have to do it the other way around. FL will automaticly slave to Sonar/HS when you do this... I think.
Two wrongs don't make a right, but two Wrights once made an airplane...
Old 10-15-2003
Junior Member
Thanks, Moskus. Yes, FL slaves to HS just fine, but it would be nice if HS would slave also. Sometimes I'll want to have tracks recorded in both and work with the FL interface while still hearing the tracks recorded in HS. I can hit play in HS and then jump to FL but that's kind of kludgey.
Old 10-15-2003
moskus's Avatar
I really don't think you have a choice when you use FL as a DXi. Maybe it would work if you just slaved HS to FL via MIDI (using Hubis Loopback utility or something like that)...
Old 10-15-2003
Junior Member
Thanks, I've never heard of Hubis before.
However, it doesn't seem like there's anything in HS's documentation that mentions it being able to recognize midi start or SPP and I have found that it definitely doesn't recongize MTC.
It seems like a pretty basic function to be missing. You should be able start the sequencer from a remote midi controller in case your sitting at a keyboard away from your computer. I think it's part of Cakewalk's dastardly plan to wrestle $379 dollars out my wallet for SONAR.
Old 10-15-2003
moskus's Avatar
I know that HS 2002 isn't able to slave to another MIDI device, don't know about HS2004. Sonar can slave to MIDI devices though...
