Old 10-08-2003
vbass vbass is offline
Newbie
vbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond reputevbass has a reputation beyond repute
audio snake between studio rooms
Hello everyone, I'm building a couple of walls in my studio to create a drum room. I'm looking for suggestions on getting the audio cables/connections from the drum room into the control room. I was going to just get some XLR &TRS wall plates and run the snakes sealed inside of the walls. However, it would be convienient to possibly run a conventional pre-built audio snake (XLR box to XLR fan) through the wall in some way that I could remove it and re-install it when necessary. The only issue is doing it in a way that does not effect the sound level (leakage) through the wall. I have wall plates hard wired in other rooms but I was thinking that a removable snake that I could also take to a gig would make more sense. Any suggestions?
Old 10-08-2003
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
Yeah, don't do it. You'll lose too much isolation to make it worth it... Steve
Hey, I thought this was gonna be EASY!??!
Old 10-08-2003
Rocket Boy's Avatar
Rocket Boy Rocket Boy is offline
Force of Nature
Rocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant futureRocket Boy has a brilliant future
where do you get/make the wall plates?
Old 10-09-2003
knightfly's Avatar
It would probably help if we knew what country/region you're from... Steve
or
http://web.ask.com/web?q=buy+XLR+wall+plates&o=0&qsrc=0
Old 10-10-2003
RICK FITZPATRICK's Avatar
RICK FITZPATRICK RICK FITZPATRICK is offline
Been Here, Posted That
RICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond reputeRICK FITZPATRICK has a reputation beyond repute
Well, when I want to make something, I usually GO out into the shop to make them.
I usually layout what it is I'm going to build in Autocad or on paper. List the things I need. Gather them. Measure them. Machine them. Assemble them. Install them. In this case, how many lines and what type? I assume your talking mic lines, but there are midi lines, line level lines, computer lines etc. In the case of mic lines. You need the XLR chassi mount which are available from most music stores, Rat Shack, or electronic stores. Even multi outlet wall plates are available as a blank plate, or as a plate similar to a wall electrical outlet plates. In my case, I hate spending money I can use elsewhere, so I usually build ANYTHING that I can to save money. Hell, were only talking a plate of aluminum, or extrusion of some type. Most commercial plates are stainless steel. DO NOT buy a plate of Stainless. Have you ever tried to drill an 1/8" hole in stainless? Even 20 gauge. Ha! Try a 5/8" hole. Ain't gonna happen. That is unless you have tools that will handle stainless. Thats why I suggest 1/8" aluminum plate. Much easier. Or 18 to 16 gauge mild steel.
Figure out how many mic inputs you need and lay them out on a sheet of thin carboard. You can usually find aluminum plate at a hardware store like True Value, or any metal supply house. Your lay out will determine the dimensions. Metal supply houses will usually cut a plate for a small fee. Or the hardware store may have a size that you can use.
Tape the cardboard or masking tape to the plate. Pre punch your centerlines with a metal punch. Pre drill 1/8" holes. Usually, chassi mount XLR's have the main jack hole, and two holes for fastening. I usually drill the fastening holes after I have the jack inserted into the jack hole in the plate, which I usually drill first. You can use a hand drill, with a multi step metal drilling bit, or in a drill press. Once the main holes(I think 5/8" is the size but may be wrong-verify it when you buy them. Usually, I'll drill the holes for fastening to match a 1/8" rivit. But you can use machine screws too.
Unless your in a hurry, I get much more satisfaction out of building things for my studio than buying things that I can make. I've even built my own console out of welded steel and other materials. I am posting the assembly pics of the console on the analog forum, cause my studio is all analog. The members there seem to be more interested in this sort of thing than here. This forum is for complete studio design and building. Anyway, hope this helps. Don't be afraid to build stuff. Every project completed will give you confidence in the next. Steve has built his own console also, I believe. BTW, Steve(knightfly) is an EXCELLENT builder and can pretty much tell you how to build anything. My best advice is planning. Flying by the seat of your pants may be ok in a plane, but building things requires a little forethought. Ok, I'm done.
fitZ
alright breaks over, back on your heads!
Old 10-10-2003
knightfly's Avatar
I've since found out where Rocket Boy's from, and that there is access to tools and expertise in the form of a "contractor dad" so, yeah, if money's tight that would probably be an option... Steve
Old 10-10-2003
skippy's Avatar
skippy skippy is offline
1K Silver Member
skippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of lightskippy is a glorious beacon of light
We were just talking about some wallplates I made to run my signal pairs around here in the new house: http://homerecording.com/bbs/showthr...hreadid=100292 .
I posted a few pictures that may also give you some ideas.
Old 10-10-2003
Rocket Boy's Avatar
Force of Nature
Wink
lol. uhh, yeah, i dont think we'll need to bust out the contractor dad on this one. i also didnt know they made these... so yeah, now i see their easily and cheaply available on zzounds.
