Old 10-07-2003
Yadi Yadi is offline
Senior Member
Yadi is on a distinguished road
Is Antares Autotune 3 worth the bread?
I use Sonar and would like to hear from Sonar users who use this product. I know purists don't endorse it, but it could become a useful tool.
Old 10-07-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
Re: Is Antares Autotune 3 worth the bread?
If you can sing, but have occasional pitch problems, it is an excellent tool.
If you can't sing, save your money. You still won't be able to.
If you decide to go for it, make sure to learn and use its graphical mode. Automatic mode is a complete waste of time, and the results are horrible.
Old 10-07-2003
James Argo's Avatar
James Argo James Argo is offline
Fancy Rock N' Roll
James Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond reputeJames Argo has a reputation beyond repute
Lightbulb
What the almighty dachay said...
I just realized that my general audio editing time is:
15% on compressor/gate/limiter plugins
15% on reverb plugins
10% on chorus/modulation
10% on noise reducing
...and 50% on Autotune
It's good, but not that easy to tweak...
BTW, I used it occasionaly with CoolEdit Pro 2 while editing.
Keep Rockin' and Rollin'...
Old 10-07-2003
keerus's Avatar
keerus keerus is offline
Junior Member
keerus is on a distinguished road
no way
the automatic mode is NOT a waste of time. if you have a very good vocal track, and you use the automatic, it will turn it into a perfect take (in terms of pitch, anyways). the graphical mode is powerful, too, but not so powerful as to make the automatic mode useless. most people use automatic as opposed to graphical anyway. make sure you keep in mind, though, that it won't turn someone who's tonedeaf into some great broadway singer.
justin
Old 10-07-2003
dachay2tnr's Avatar
One Hit Wonder
Re: no way
justin
Sorry, have to disagree here.
Automatic mode will work on every note - which you hopefully shouldn't need to begin with. It will tend to make the track sound unnatural (as you might expect a "perfect" track to sound)It will often make wrong decisions as to which note to correct to, eliminate many of the vocalist's nuances, and it is death on vibratos (tends to make them sound like quivers).
Use graphical mode, and only use it where necessary. If you want automatic mode, buy OBTune and save yourself a bunch of money.
Old 10-07-2003
tkingen's Avatar
tkingen tkingen is offline
Banjos Rock
tkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond reputetkingen has a reputation beyond repute
I've never used Auto-tune, so please correct me if this is wrong...
I would guess that you would highlight only the note that needs correction, or maybe split that note into it's own clip for processing.
It sounds like you guys are using it to process an entire track?
Terry Kingen
Old 10-07-2003
Qwerty's Avatar
Qwerty Qwerty is offline
1K Silver Member
Qwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond reputeQwerty has a reputation beyond repute
Being the perfectly pitched singer that I am, *harrumph*, I have never found the need to use Autotune.
However, when I have been tracking my incredibly tone deaf friend, Scott - (yes, he is reading this thread), I use it in Automatic mode as Terry describes above.
- Highlight the dodgy note
- Set the voice type
- Set the key
- Fiddle with the correction parameters so as to avoid the dreaded "Cher" effect
- Problem solved.
I do agree with Dachay though that using it to just blast an entire track will make it sound weird. It comes out as somehow too correct and doesn't do good things to your ears.
The best vocal tracks do typically include some degree of pitch sliding into and out of notes for most contemporary music. It is hard to preserve these "nice" pitch slides when throwing Autotune at a track to fix other more glaring errors.
Ciao,
Q.
<insert something witty here>
Old 10-07-2003
dachay2tnr's Avatar
One Hit Wonder
Terry Kingen
Actually you tend to work with phrases. In my experience you need to cut out a clip that has a bit of a pause both before and after. It is pretty difficult to cut out just a single note, without creating problems,
However, using graphical mode allows you to just apply correction to a single note within the phrase. Or even to just a portion of the note if you desire.
Automatic mode, in that example, would be applied to entire phrase. However, in my experience, most people use automatic mode on the entire track.
It probably works OK in Qwerty's example, but I would still use graphical mode, which allows you to control exactly where and how much correction is applied.
The thing most people miss (IMHO) is that some degree of pitch deviation is not only normal, but is actually more pleasing to the ear. A track that is perfectly in pitch will tend to sound robotic and cold.
The appropriate use of autotune is simply to correct the occasional note that "sounds bad." Or more accurately, that sounds bad because of intonation.
Old 10-07-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Re: no way
I disagree as well.... the worst way to use autotune is throwing across a whole track.
Old 10-07-2003
crosstudio's Avatar
crosstudio crosstudio is offline
Reggae + Go-Go = Regg'go
crosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond reputecrosstudio has a reputation beyond repute
i use automatic mode when i'm dealing with a singer whose off-key singing is only noticeable on long notes.
otherwise,
i use graphical mode for real vocal surgery.
Old 10-07-2003
Senior Member
Ha...thats a good analogy.
I've played around with their demo, using the auto feature, across entire tracks. Even when the vocals are 98% in tune, it seemed to create an unatural Cher effect on notes as they varied pitch....does that make sense?
So...I think I probably would use it on phrases or "soundbytes" or even less.
I can't remember the layout, but is there a control of "attack" with it?
  #12
Old 10-08-2003
MaKettle MaKettle is offline
Newbie
MaKettle is on a distinguished road
I agree that it's best to use graphical mode on vocals, but I must say that I accidentally pitch corrected an entire double bass track and it didn't sound noticeably unnatural, as it does on vocals. I intended to undo the mistake, but after listening to the track, left it corrected. I suppose which mode you use could depend on what you are correcting. With vocals, it's biggest benefit is that it can save time, and a singers voice, since you won't have to do a zillion takes to get through a few trouble spots.
  #13
Old 10-08-2003
Qwerty's Avatar
1K Silver Member
I have only ever played with a demo and an old colleague's copy. What does it go for these days?
Q.
  #14
Old 10-08-2003
tombuur's Avatar
tombuur tombuur is offline
Dedicated Member
tombuur will become famous soon enough
Never tried this Antares autotune. There are other similar products I haven't tried either. Which one is the best?
I have a TC-Helicon VoiceWorks bought for live use and chorus primarily. But it can do pitch correction and has a 24 bit digital interface, so I guess it could be an alternative for me.
TBuur
  #15
Old 10-08-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
I'm guessing that Antares Autotune is the industry standard because it is the best, but I don't know...
Apparently Melodyne 2 is now a plugin and can be used via ReWire.
Two wrongs don't make a right, but two Wrights once made an airplane...
  #16
Old 10-08-2003
tombuur's Avatar
Dedicated Member
So Antares it is. Don't know if I need it though. The TC-Helicon is okay in live situation where you can't always hear your own voice perfectly and also got part of your attention focused on the guitar. In case of recording I believe I get pitch okay. This could mean two things:
1. I am good at hitting the right pitch
2. My self-assessment is lousy
So if the Antares or other device doesn't make the vox sound worse, maybe you should apply it just as a safety precautions? Some listeners may have a better perception of pitch than you have.
TBuur
  #17
Old 10-08-2003
pdaniels pdaniels is offline
Junior Member
pdaniels is on a distinguished road
If you listen to the radio, every pop song sounds totally in tune. You can't get away with "kind of" being in tune today if you want to sound at all mainstream or commercially viable.
This isn't the 80's.
If you ask your average person on the street if somebody can sing (is a singer any good), he will consider 2 things to decide: pitch accuracy and performance, and usually with much more importance on pitch. At least there is a way to ensure you are always in tune.
I also sing quite in tune, but I use pitch correction as a failsafe to ensure I am always totally in tune. This way I don't listen to something I recorded and say "what was I thinking? that note is kind of flat!"
I have a Voiceworks also, and I track vocals through it. It took a few days to get used to monitoring my voice post-correction while singing, but it has made a big difference because the results sound more natural than Antares.
Hope that helps...
  #18
Old 10-08-2003
Chris Shaeffer's Avatar
Chris Shaeffer Chris Shaeffer is offline
Peavey ROCKS!!!!!!!!!!!!!
Chris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond reputeChris Shaeffer has a reputation beyond repute
I found it really usefull (even in automatic mode) for the lots and lots of backing tracks that I sometimes do. 12 tracks of vocals, all set really low in the mix, really jell together when they are in tune...
...and I'm typically up ***very*** late at night when I decide to do such silly things with my voice and the autotune is saving my hours of trying to fix something that I could never get perfect anyway.
I never use it on the lead vocal track, though I might give it a try with graphical mode. I usually like to leave the lead natural. Who cares if its a little pitchy? Its real.
Take care,
Chris
  #19
Old 10-09-2003
tombuur's Avatar
Dedicated Member
pdaniels,
Thanks for your information about VoiceWorks. If you think it sounds better than Antares, why would I spend money on the latter, already owning a VoiceWorks. I do, however, wonder why you don't just track the vox and then pitch correct afterwards, since VoiceWorks can connect digitally. Never tried it myself, though. Also I have found VoiceWorks to add some noise, but this may only be through analog connection?
Anyway, concerning pitch correction. One of the local Danish bands (singing in English) at the moment have a hit, regurlarly played on the radio. The lead voice is weak and slightly out of tune all the time. Somehow they have created a great result by breaking the rules here.
TBuur
