inca 88 doesnt work under sx..
i already posted this in the computer/soundcard forum, but without getting any replies.. so i try it here:
i spent a couple of hours installing the inca 88, it was that bad that my pc even didnt boot AT ALL when it should, otherwise it just gave up right after the memory count.. i still dunno if it does work, cause today it didnt boot twice, again -_- so heres the actual problem: i use cubase sx, so i went to the device settings / vst multitrack, and the inca asio driver was already selected (!) - so it was like, "great, everything should just b perfect this time".. but well if i want to choose the inputs (of which the inca has 8), i can only choose "in 1" and "in 2", however, these two routing options dont actually point to any of the actual inputs.. so i cant record, at all! before this card i have the waveterminal 2496 in it (where there were 2 inputs..) - but of course i removed it, and deleted all the drivers.. but it just seems like cubase didnt notice the change.. lol. although it automatically switched to the inca asio driver.. i hope someone can help me out, currently i cant do anything ![]() |
I also have a multiple input soundcard, and this is what I have to do. Hit F5... this will bring up the Vst Inputs menu. Now activate the inputs you want to use. Then you can pick an input for each track. I used to have to do this each time I started Cubase, but then I figured out that I can save my configuration to a template.
Much easier... |
you're right! thanks man..
