Old 10-05-2003
randyfromde randyfromde is offline
Dedicated Member
randyfromde is on a distinguished road
Reverb settings to "fatten" things up a bit
Could someone suggest some settings for me to try and make a track a little more "full" without a real audible reverb-y sound? Sometimes I record a vocal part which I don't want to double, or an acoustic guitar line that I'd like to be a little more full.
Thanks!
Old 10-05-2003
M.Brane M.Brane is offline
Part-time amateur AE
M.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond reputeM.Brane has a reputation beyond repute
When I think of "fattening" a track, reverb isn't the tool I think of. I think more of strategic EQ or a bit of chorus. To me reverb is for adding "space".
You could try a dark small room verb with a short predelay and decay.
Old 10-05-2003
Dedicated Member
Oh okay. Yeah, it doesn't have to be reverb, that's just what I thought would do it.
Basically, I'm trying to get a fatter sound without double tracking or having it sound like there is an echo.
Old 10-05-2003
Compression is also a useful tool for "fattening". It depends on your definition of fat. The key is to add just enough to fatten without making mud.
Old 10-05-2003
Neurotic Neurotic is offline
Newbie
Neurotic is on a distinguished road
Re: Reverb settings to "fatten" things up a bit
Thanks!
Try a small room reverb type - 30-40%.
Then set the mix (wet/dry) level between 5-20%.
Set the pre-delay as much as possible. (vocals)
Increase send level on mixer or plug in so that vocal sounds more
present and bigger.
I.e.:
You want a big room sound, with a low mix level and as longs as a reverb tail as possible as long as it isn't audible. Send it to your mixer at full level with little pre-delay...and
that should work. If your plug in or effects unit has damping, increase the amount of damping everytime the reverb amount is increased to keep the reverb from "drowning" the sound out. Ambience is achieved perfectly is this is done right.
Old 10-06-2003
Beezoboy Beezoboy is offline
Home Recording Guru
Beezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant futureBeezoboy has a brilliant future
A short .5 second small room reverb on a guitar solo or lead track can really make it stand out in a mix. The same goes for snare too.
Beez
My mic collection sucks now, but at least I have a girlfreind.
Old 10-07-2003
StevenLindsey StevenLindsey is offline
Force of Nature
StevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond reputeStevenLindsey has a reputation beyond repute
Many times using reverb to make something more "full" will actually make it "muddy." To me, what makes a track sound "full" is a good strong clean signal going from a well-tuned, fine sounding instrument into a decent recorder with the input at the optimal level. A small amount of reverb can sometimes nicely place a track like that.
Old 10-07-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Also... a well-placed delay instead of reverb can thicken, rather than "muddy" a track's ambience.
