Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 10-04-2003
Nigie Nigie is offline
Junior Member
Nigie is on a distinguished road
Clicking as song line passes over audio loop joins
Another new to SX1 question:
I've imported some audio loops from my Acid library and they make a click noise as the song line passes over the point where I join them together. I've tried fade ins and fade outs at the beginning and end of each loop but this makes no difference.
Is there any de-clicking mechanism anyone?
Thankyou
Old 10-05-2003
ron82 ron82 is offline
Senior Member
ron82 is an unknown quantity at this point
these clicks occur if there is a sudden amplitude change (which might occur if u "glue" two different audio parts together..)
what i do (cause i dont know better), is setting a crossfade (very small, at like 1/64 quantize..)
that will solve the problem, but i doubt its the professional way to go lol
Old 10-05-2003
Track Rat's Avatar
Total Gear Slut
You have to make your cuts at a zero crossing. If you make a cut anywhere else, you get the "pop".
Old 10-05-2003
Junior Member
Look thankyou so much for replies. The auto cross fades I think have nailed it Ron. I will adopt this as a highly professional technique and will say I learnt it from a seasoned professional!! - very quick, easy and effective!
Track Rat I'm not sure what cutting at a zero crossing is but guess you could mean I should try to cut an audio piece at a point where it either has zero (or close to zero) volume or where at least the volume matches the volume of the next piece of audio I want to put on the track - volume matching so to speak? Hope this is what you mean. If so sounds like good advice.
Thankyou both. You've saved me much struggle..
Nige
Old 10-05-2003
trogdor's Avatar
trogdor trogdor is offline
Dedicated Member
trogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond reputetrogdor has a reputation beyond repute
Yea splicing at zero-crossings is probably the best way to do it if at all possible. They are the points in the wave where it crosses zero amplitude and thus creates a seamless loop when you have zero crossings at the head and tail of your loop.
Most audio editors worth their salt will have a feature that allows you to "snap to zero-crossings"...making it easy to select and edit seamless loops in a flash.
TROG-DOOOOOOOR!!!!
www.rayjonesspecial.com
www.a440studios.com
