Old 10-02-2003
callipygian callipygian is offline
Newbie
callipygian is on a distinguished road
another question about micing amps
Hello,
I've been trying for the past two days to find some nice spots to place my mics to catch the sound at a decent quality. If i'm playing clean, slower or picking notes I can get it to sound satisfactory, but when I'm strumming chords the distortion really comes out when i playback the recording, which would be the desired thing if it didn't sound so terrible. I'm just trying to save myself from more hours of experimenting than needed by seeing if there's anybody out there that can give me suggestions according to the gear I have. So, here it goes:
*Peavey Bandit 112 (original speaker replaced with a celestion)
*Cad 95 (small diaphragm condenser, I've been using this to close-mic the amp)
*Studio Projects C3
*Audix Fusion drum mic set, which consists of:
- 2 - small diaphragm condensers with responses aimed for the high end
- 3 - tom mics which can probably be used if I want to mic the amp with more than the 2 mics I'm already using (ie. mic the back of the amp)
- 1 - mic aimed for the lower frequencies of bass drums or floor toms
*2 omnidirectional shure mics that may come in handy in times of desparation
Mics run into a Mackie, then to the soundcard...
I haven't tried micing the back of the amp yet, nor have I recording the same track twice and panning them and whatnot, because I figure that if I'm not happy with the original sound, then when I add more to it I will be equally as unhappy at best.
So, does anyone have any suggestions, or should I just keep trying, maybe add some compression or other misc plugins.......or should I give up, consider it a lost cause, sell all my crap and buy something a little less complicated like a pet snake? Or maybe I'll just become a mime.....
Oh yeah, and what exactly are you doing when you're swapping the pin phase?
Old 10-02-2003
Mark7's Avatar
Mark7 Mark7 is offline
Human 2.0
Mark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond reputeMark7 has a reputation beyond repute
I'd hazard a guess that you're overloading the Cad. Does it have a pad switch?
Second possibility. Your levels going into the Soundcard are too high and you're getting clipping. In which case lower the main output fader on the M*ckie.
Orbiting this at a distance of roughly ninety-two million miles is an utterly insignificant little blue green planet whose ape-descended life forms are so amazingly primitive that they still think digital recording is a pretty neat idea.
Old 10-02-2003
sloop's Avatar
sloop sloop is offline
Dedicated Member
sloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond reputesloop has a reputation beyond repute
Ah, perhaps you need to check
Check the input gain control. Mackies, especially the older ones, are sensitive to hot inputs. You are using condensers so the input gain should be set pretty low. You can bring the fader up, it's the pre-amp before it gets to the fader that will overload if the signal is too hot.
It can do this well before the peak light goes off so try turning down the input gain and bring the fader up to get the levels you want. If this doesn't work, the mics themselves could be overloading.
Just a couple of thoughts, give them a try.
Old 10-02-2003
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Thumbs down
Ditch the Bandit.
Old 10-02-2003
grinder's Avatar
grinder grinder is offline
Force of Nature
grinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond repute
Originally posted by chessrock
Ditch the Bandit.
Yeah, I agree.Hands down, the worst sounding amp I've ever played through.
Old 10-02-2003
Newbie
It's definately not a clipping problem, because I did set the levels to be around 0 db when the faders were at unity. I was afraid that what it was going to boil down to was the bandit. I don't have the cash to buy a better amp because I spent all my money on monitors, mics, soundcard, etc. So that sucks. I guess I'll just become a mime with a pet snake....
Old 10-02-2003
grinder's Avatar
Force of Nature
Can you hear the distorion coming from your amp or are you just hearing it on playback?If it's not coming from the amp then it sounds like something in the chain is clipping.Have you tried differant mics?
Old 10-04-2003
jimistone's Avatar
jimistone jimistone is offline
1K Silver Member
jimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond reputejimistone has a reputation beyond repute
"Ditch the Bandit."
I have some recordings done with a bandit that sound really good.....I also have some recordings that i used a fender tube amp that sound good. Im going to put a couple up on nowhere radio in the near future. One blues guitar solo that was done with a bandit has as good a guitar tone as i've ever heard. The signal chain is:
1966 fender stratocaster into peavey bandit.
mic'd with a SP C-1 LDC going into a joe meek "british channel" pre...(so don't tell me that a dynamic mic or a ribbon mic is the only way to get a decent recording of a guitar amp....thats bullshit)
So, with that said I will say this...
don't ditch the bandit....
tweak the bandit
"if it sounds right it IS right!"
my music...More than 1 song now!!
The movement you need is on your shoulder
Old 10-04-2003
shackrock's Avatar
shackrock shackrock is offline
1K Silver Member
shackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond reputeshackrock has a reputation beyond repute
turn youyr distortion down? ha.
or, maybe the mic itself is clipping. pack on a few pads into your chain.
Scott Solo
Old 10-04-2003
jimistone's Avatar
1K Silver Member
Probably the best advice I can think of to give someone having trouble getting a decent guitar sound...
turn down the distortion!
damn shack...you beat me to the punch
lol
Old 10-04-2003
Newbie
I usually play with the distortion at a numeric level of 6 or 7 on my amp, and because of the fact that I have read up on micing amps at various places, I was aware of the "turn the distortion just below where it sounds good to the naked ear" measure. I experimented with various levels, and was at the point where I was between 1 and 1.5 when I came to you guys for help. At that level it sounds good when I play a a more slower style, but the second I start strumming, it sounds like crap. My main trouble is with the higher frequencies, I think, but when I turn them down either on the amp or on the microphones, it lacks definition and is muddy. If the mics were clipping, when I press the solo button on my mixer, the led levels would be topped out when the fader for the mic's channel was at unity gain (0db), no? I'm next to positive the mics aren't clipping.
Thank you everybody for helping, any further suggestions are welcome, but what I'm starting to think is that if I want to do any recording out of my amp at all, I'm just going to have to do the arduous and tedious task of positioning the amp and microphones in just the right spots, with both the amp and the mixer's eq's in just the right spots, doubling up the tracks with layers of clean and distorted recordings of both bridge and neck pickups, then use a load of plugins to chop it into pieces, turn it upside down and smear it all over steinberg's face.
  #12
Old 10-04-2003
grinder's Avatar
Force of Nature
I think that you can have mic clipping without clipping your channel signal.Try turning down your amp level or moving the mic away from the speaker some.
