Home Recording
Go Back   Home Recording > General Discussions > Newbies
Thread Tools Display Modes
  #1
Old 2 Weeks Ago
cadbawdbawks cadbawdbawks is offline
Newbie
cadbawdbawks is on a distinguished road
Would a preamp make much difference on vocal recordings? How?
Hi all,
I was wondering if a preamp would make much difference on vocal tracks. I was thinking specifically of the ART TubeMP Studio V3 preamp. If indeed it does, how will this improve the sound quality? Any help is much appreciated!
Thanks for taking your time to read this!
  #2
Old 2 Weeks Ago
Jim Lad's Avatar
Jim Lad Jim Lad is offline
Dedicated Member
Location: Born in Scotland, Irish Descent, Living in Canada.
Jim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond repute
You were concerned about sounding muffled.
A tube amp would only make that worse really.
__________________
Cheers ♫
Jim
  #3
Old 2 Weeks Ago
Newbie
I've realized though that when i record my vocals, my interface has a tendency to clip all the time unless I record at such a level that i can barely hear myself in my headphones. Would a preamp solve this?
With regards to the muffling, is this the purpose of tube amps?
Thanks
  #4
Old 2 Weeks Ago
gecko zzed's Avatar
gecko zzed gecko zzed is offline
audio illusion
gecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond reputegecko zzed has a reputation beyond repute
No . . . a preamp is not going to help you at this stage.
If you are clipping your signal, yet unable to hear yourself, the problem lies in the monitoring path, not the recording path.
You should be able to get a very good sound recorded without a dedicated pre. Until you get this, there is nothing to gain by the addition of a pre.
__________________
I have a theory about that
  #5
Old 2 Weeks Ago
Newbie
Would there be a solution for the issue with my monitoring path then?
Thanks for the reply
  #6
Old 2 Weeks Ago
Dani Pace's Avatar
Dani Pace Dani Pace is offline
Why 2K?
Dani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond reputeDani Pace has a reputation beyond repute
Turn up your playback/monitor volume. You should never clip the input signal.
__________________
The more I learn, the more I realize how much I don't know. http://www.soundclick.com/sixfeetover
  #7
Old 2 Weeks Ago
villainrecordin's Avatar
villainrecordin villainrecordin is offline
Newbie
villainrecordin is on a distinguished road
iv never had that problem but you could try using a limiter, i typically hate limiters for vocals but if it helps it helps.
  #8
Old 2 Weeks Ago
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
Not at the input ---
If you're even *approaching* clipping, you're very likely overdriving your input chain. You're waaaaaaaaaaaaaaaaaaayyyyyyyy too hot.
Brushing up on basic gain-staging would be the place to start.
__________________
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
  #9
Old 2 Weeks Ago
Newbie
Quote:
My monitor volume is already at max, is there any other solution? Thanks
  #10
Old 2 Weeks Ago
Jim Lad's Avatar
Dedicated Member
Depends on your equipment.
Sometimes the headphone volume control is tied to the monitor volume control.
So even if your headphone is turned up all the way, you won't hear anything until you turn the monitor up.
Other equipment has a "Share" set up whereby you choose 0-100% playback versus input.
In other words, you control how much of yourself you get to hear while playing back the prerecorded tracks.
What equipment are you using?
__________________
Cheers ♫
Jim
  #11
Old 2 Weeks Ago
jimmy77611 jimmy77611 is offline
Junior Member
jimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond reputejimmy77611 has a reputation beyond repute
What interface are you using?
  #12
Old 2 Weeks Ago
darrin_h2000's Avatar
darrin_h2000 darrin_h2000 is offline
Been Here, Posted That
darrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond reputedarrin_h2000 has a reputation beyond repute
Quote:
Thanks
Not all preamps are going to be an improvement...cheap ones will degrade the signal...ART makes alot of those...nobody makes a tube pre that is useable without bumping up the voltage enough to actually use the tube...and you wont get that with a preamp that uses an AC/DC adapter.
__________________
wayne
  #13
Old 2 Weeks Ago
Newbie
I'm currently using a Tascam US122 Interface and an mxl 990 mic.
The interface does indeed have the phones and direct monitor volume controls. I've actually already turned up both to the max and still I can't hear much if I record at a level that does not clip. Thanks for the tip though
  #14
Old 2 Weeks Ago
Vinnydude Vinnydude is offline
Registered User
Vinnydude is on a distinguished road
Just a thought, but maybe try turning everything else down a bit?!
  #15
Old 2 Weeks Ago
gecko zzed's Avatar
audio illusion
Just a thought. Is it possible that you need to turn the direct monitor control the other way? Sometimes these controls act like a pan between input (what you are trying to record) and output (what you have already recorded).
__________________
  #16
Old 2 Weeks Ago
Rust E-Z's Avatar
Rust E-Z Rust E-Z is offline
Life long Newbie
Rust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond reputeRust E-Z has a reputation beyond repute
Your not singing into the back of your mic, are you?
__________________
"There are two kinds of people, those that pigeonhole everybody into two generic categories, and those that know better"
  #17
Old 2 Weeks Ago
Jim Lad's Avatar
Dedicated Member
Have you enabled "Direct Monitor"?
4 – Hooking up Audio and MIDI to the US-122 TASCAM US-122 — 17 Using Direct Monitoring In digital and computer audio, the amount of time it takes for the input sig- nal to pass through the circuitry of the unit and the software processing and arrive at the outputs will sometimes result in an audible delay (this is com- monly referred to as “audio latency”). This added delay can be confusing when, for example, you’re trying to overdub to previously recorded tracks. The direct monitor feature built into the US-122 eliminates this problem by pro- viding a way to listen to the signals you’re recording directly, without any computer processing delay. When the DIRECT switch is on, the sound passed through the USB and computer process- ing is not monitored, and the input sig- nals are passed directly to the outputs for monitoring. You can use the DIRECT MONITOR level control to set the level of the directly monitored signal, and the MONO switch to fold the two direct monitor stereo channels into mono. The LINE OUT and PHONES level con- trols directly affect the audio levels that appear on the LINE OUTPUT and PHONES jacks, respectively.
__________________
Cheers ♫
Jim
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Google
Similar Threads
Will using R-10 instead of R-13 make any difference? Bill Furnett Studio Building & Display 4 08-17-2006 13:02
does using a preamp really make a difference? xfatalherox Recording Techniques 5 06-30-2004 19:19
How much difference does the preamp make? AndyCarpenter Microphones 16 01-20-2004 07:10
preamp vs tube preamp : difference? fadedstar Newbies 8 10-22-2001 11:41
does it make any difference by using a preamp jungkang Microphones 6 08-04-2001 22:19
Powered by: vBulletin
