Home Recording
Go Back   Home Recording > General Discussions > Digital Recording & Computers
Thread Tools Display Modes
  #1
Old 3 Weeks Ago
tigerflystudio's Avatar
tigerflystudio tigerflystudio is offline
Newbie
tigerflystudio is on a distinguished road
M-Audio Fast Track USB recording delay / out of synch
Hi, I have been trying to use the M-Audio fast track USB to record guitar on my PC. After downloading the latest drivers from M-Audio's website (for Vista 32 bit SP1) I tried doing a few recordings.
The problem: I am hearing the audio from the PC fine, and I am hearing my guitar perfectly fine and in synch. But when I listen back to the recoridng, it is out of time with the first track.
I wondered if it might be a latency issue? (Although I am hearing everything in synch whilst recording - it's only upon play-back that the newest 'take' seems to have recorded slightly too slowly (delayed).
I changed the latency sllider in the Fast-Track menu (which seems to be the only slider there is in that menu) from 256 to 128 and then re-recorded some guitar. I noted (after a rather long-winded test) that the first recording (256) was delayed by 53ms. The second recording (128) was 48ms delayed.
Any ideas on how to cure this? I'm new to PC recording and this is really doingy head in.
  #2
Old 3 Weeks Ago
Jim Lad's Avatar
Jim Lad Jim Lad is offline
Dedicated Member
Location: Born in Scotland, Irish Descent, Living in Canada.
Jim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond reputeJim Lad has a reputation beyond repute
Yes. That's what latency is.
If you are adding more tracks, simply mute that one while recording and the new track will line up with it.
Yes.
Upgrade.
If you move up to the Fast Track Pro or similar Audio interface then you will start using ASIO which is basically designed to reduce latency.
The Fast Track USB is entry level and doesn't support ASIO.
__________________
Cheers ♫
Jim
  #3
Old 3 Weeks Ago
Newbie
thanks again, Jim. Thing is, I need to hear the other tracks to play along to, but I guess if I'm just doing a few bare acoustic tracks that could work.
If the Fast Track USB has this kind of latency and it can't be gotten around, how do M-audio sell any?! Is there really no work-around? If not, it really is a totally useless unit for multi-track recording.
Looks like I might have to stick with the multi-trackers and trasfer the files to PC via USB (as I have been doing). It begs the question, is there any interface for the PC which provides true, 100%, zero latency?
  #4
Old 3 Weeks Ago
TeyshaBlue's Avatar
TeyshaBlue TeyshaBlue is offline
Life is Sweet....
TeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond reputeTeyshaBlue has a reputation beyond repute
I agree with Jim, it's undoubtably a latency issue. However, I would be extremely surprised if it were enough to be noticeable. Even with WDM drivers, a simple USB interface moving 1 or 2 tracks at a time should not introduce noticeable latency.
Keep adjusting the latency to the least possible and see if that helps.
I used a simple, 1st. generation Tascam US-122 for a couple of years...building projects of increasing complexity. I never, ever, had a latency issue that was noticeable.
I suspect that what ever software you are using to record with, that you have enabled the monitor/echo function on the playback track. This will add significantly to the latency. Deselect this on each track.
You have direct hardware monitoring on that interface...use it. It should solve your problem.
__________________
www.myspace.com/colabrei
I'm hung like a Naiant.
  #5
Old 3 Weeks Ago
Jim Lad's Avatar
Dedicated Member
You're the 3rd one in two days with the same model.
I bought one (against the shopkeeper's advice) simply to see if I could record on my PC.
I kept it for a month then passed it on.
It served its purpose.
What I did was
1) Record my foundation track. (Guitar & Vocals, one mic)
2) Record my guitar.
3) Mute the guitar during playback while recording the vocals.
4) Mute the foundation track and playback the other two. They should be in perfect sync.
5) Bought an M-Audio, Fast Track Pro and put the other interface back in the box.
__________________
Cheers ♫
Jim
  #6
Old 3 Weeks Ago
TeyshaBlue's Avatar
Life is Sweet....
What I did was
The latency is really that bad? Amazing they sell any of 'em!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Google
Similar Threads
FS: M-Audio Fast Track USB dustinH Free Ads for Music / Recording Equipment 0 06-23-2008 17:52
M-Audio Fast Track USB - USB 1.1?? stodge Digital Recording & Computers 10 04-25-2007 19:24
M-Audio Fast Track USB...? valuehorse Other Equipment and Reviews 6 04-24-2007 10:55
M-audio fast track USB emomusician Digital Recording & Computers 0 01-24-2007 12:17
m-audio mobilepre usb or Fast Track USB or What??? Cascoballa DJ & Hip Hop Production 2 07-10-2005 21:56
Powered by: vBulletin
