Home Recording
Thread Tools Display Modes
  #1
Old 3 Weeks Ago
Folkcafe's Avatar
Folkcafe Folkcafe is offline
Just trying to help
Folkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond reputeFolkcafe has a reputation beyond repute
Dodgeaspen
Compare the STC ratings of a non-insulated and an insulated wall and let me know if you wish to revise that statement.
From stcratings.com
Sound absorptive material can be installed inside of a partition's air space to further increase its STC rating. Installing insulation within a wall or floor/ceiling cavity will improve the STC rating by about 4-6 dB, which is clearly noticeable. It is important to note that often times, specialty insulations do not perform any better than standard batt insulation.
While not a ton better than the airspace in between the floor and ceilng layers, every bit of the plan is helpful. Hence a multi-pronged solution. Mass, mechanical isolation and insulation will net you the biggest result.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Google
Similar Threads
Soundproof basement ceiling marshall409 Studio Building & Display 8 09-10-2009 14:48
Just purchased these for my basement ceiling... Rickson Gracie Studio Building & Display 3 03-05-2009 08:46
Another basement ceiling question cellardweller Studio Building & Display 6 05-21-2008 07:49
How well will this work (basement ceiling)? cellardweller Studio Building & Display 13 04-03-2008 12:10
Drywall on basement ceiling? cellardweller Studio Building & Display 14 09-10-2007 08:21
Powered by: vBulletin
