#1
Quote:
Frank |
#2
Yup, definitely want to put some fabric on them to keep the particles from escaping. Supposedly they're harmless, but they are annoying.
I used lightweight fabric I found at the Walmart $1 bin. It's light polyester blend or something. Look for the stuff you can easily blow through, but not see through. Basically, you want the weave to be smaller than the particles. A lightweight fabric will ensure the sound gets through and absorbed without being reflected back into the room. I used spray on adhesive. I'm having problems with some coming off 8 months later, but maybe those are the panels where I was running low on adhesive. Just hanging the stuff up is such a huge improvement. It's the best bang for the buck to improve your mixes. And it doesn't have to be expensive or complicated.
__________________
Find my tunes here >>> http://www.soundclick.com/bands/page...?bandID=741321 |
#3
#4
I Think That I'm On The Right Track Now...
Quote:
Quote:
![]() Quote:
Chili, I was planning on using spray adhesive, too. Did you spray it on the entire fiberglass panel (including the front), or just on the back to keep the fabric adhering to the panel? I guess my real question is whether or not the use of spray adhesive on the front of the panel will interfere with its sound-absorbent qualities? I was going to avoid using it all over the panel because I feared that it would cripple the effect. If that is an incorrect assumption, I can simplify my project considerably. Please advise... I believe that was my REAL problem I always tend to over-think, over-analyze, and over-complicate everything! ![]()
__________________
"Guess what?! I got a fever, and the only prescription... is more cowbell!" |
#5
Puke-Mart has a lot of sales on fabric. That will be good to keep cost down. Post some pics your done.
__________________
It's easy to stand out in a crowd when the level of competence is so low. |
#6
I certainly will post some photos when it's complete!
__________________
#7
Quote:
In regards to the OC703, I suggest you also consider the Johns-Manville Fibreboard also. It is very similar to OC703/705 in size and density, but it's not flaky like 703. I had the opportunity to compare side by side and next time I will only buy the JM stuff. Buried a few pages down, I have a thread where I showed some pics and discussed the differences. Maybe search this forum for any posts I started. You should be able to find it easily that way.
__________________
#8
Quote:
Muchas gracias, amigo...
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| FS or Trade: OC 703 Rigid Insulation for Bass Traps - Panels | matthewmilner | Free Ads for Music / Recording Equipment | 8 | 02-04-2007 16:00 |
| Isolation Booth: Insulation Questions | Jack Russell | Studio Building & Display | 18 | 12-27-2005 20:45 |
| 703 rigid fiberglass insulation | Natural Gass | Studio Building & Display | 11 | 04-10-2003 09:19 |
| is faced Rigid fiberglas insulation useable?? | HangDawg | Studio Building & Display | 18 | 03-03-2003 08:32 |
| Fiber Insulation/Insulco Semi Rigid | charoo | Studio Building & Display | 4 | 02-03-2003 09:33 |
