#1
Since the recorder only has 4 mic inputs It is going to be hard to record as a band unless you go direct on the other devices.
If that is what you are doing, then I would pick the 2 LDC mics as overheads and use the bass drum mic on kick and the sm58 on snare. Use the Glyn Johns method for the overheads. (do a google) Should be fine.
__________________
Tom Menikos T-Mix Studios Mansfield Texas WWW.tmixstudio.com |
#2
We won't be recording live so I'll be able to use up to 16 tracks on it. So far, it seems like the Glyn Johns technique is the closest I'll come to getting what I want. Still looking for other options, though. Any suggestions are appreciated.
#3
The Glyn Johns or Recorderman method are your best bet in my opinion. I have 24 inputs and I still only use 4 mics on my drums; Kik, snare and 2 overheads.
#4
One thing that tripped me up the first time I tried recording drums was phase. The individual mikes sounded OK but turned into a mess when they were combined into a stereo mix. It turned out that because the mics were at different distances from the drum they were recording the sound was hitting them at slightly different times (apparently sound travels about 1 foot per millisecond) which meant some frequencies were being cancelled out so I had to manually line up the seperate drum tracks so they were perfectly in sync.
#5
That shouldn't be necassarry with proper mic placement and/or using less mics.
#6
Honestly, unless you have a figure 8 patterned mic (to do mid-side) my suggestion is your best bet.
Like RAMI, I have 32 channels of good to great converters and some pretty tasty preamps, but I generally stick with 4 to 6 mics. If you are just getting started the more is not the merrier. I would be more concerned what the acoustics were like in your room.
__________________
#7
That's the best advice you can get. Room treatment is (one of) the most important thing, and usually the most over-looked.
#8
Quote:
![]() Should I be putting the mics equal distance and concentrate more on what part of the drum they are pointing at? |
#9
Don't know? Ah well, must have "heard" it from somewhere.
#10
Yes.......
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Drum issues!!! | GreenDank | Drums and Percussion | 6 | 11-09-2005 12:54 |
| Kick Drum Beater Issues | Scottgman | Mixing / Mastering | 13 | 10-13-2005 08:57 |
| Bass Drum Mic Issues...Please Help! | Robertt8 | Recording Techniques | 7 | 01-07-2005 12:54 |
| drum sync issues w/ triton | Guernica | Keyboards and Sound Modules | 11 | 06-21-2004 11:43 |
| Acid Timing Issues And Recording Issues. | czar of bizarre | Sony Tools / Sonic Foundry | 3 | 03-15-2002 13:12 |
