What about a card like the Aardvark Q10, i was considering this a while ago.
It has the volume control for monitors built into it. wouldn't this be the absolute best, because you are doing it before it even leaves the card?
No i don't need 8 inputs most of the time. And getting 2 great channels of preamps and mics and building on that would be best, but i will want to record more tracks eventually for drums or whatever, or maybe a band. i may even want to go to a buddies house and record some drums a week after i get the setup, so it's not necisarily really far down the line, just time to time. To get the RNP, a preamp to control the monitors, and a delta 66, it would cost me about 2000 canadian dollars (estimated, maybe a bit more). That would give me a max of 4 inputs, with spdf for future upgrading, and 2 great channels of preamps, so i could only record 2 signals at a time. The Q10 would cost about 1600-1700 Canadian, and i would have 8 good preamps (not as good as the rnp, but good), better converters and a better clock, 8 inputs, a word clock port, midi, and spdf. PLUS it has headphone/mixer outputs and volume knobs for each. So i would be getting more for less, it seems? i can always add a single high quality preamp in the future to do the bulk of main signals, for the 2 i will be usually recording, and have another 8 just incase. This would also reduce the signal chain. Instead of soundcard-preamp volume control-monitors. It would be soundcard-monitors. And the same with the input signal, no outboard preamp (unitl i add one).
Does this sound like a good option? I was heavily considering it before, but changed my mind to a smaller cheaper card like a delta 44/66. But once you factor in the preamps and the volume control for the monitors, it's really no cheaper, and it seems to me that i'd be getting less. The only downfall is the preamps would be a little worse, BUT the converters would be better. I could put the extra money i saved from this towards a better mic, which i'm told will make the most significant difference...
Any good?
