....some of it will go more in your left ear and some will mostly go in your right ear....
True.....but that happens with ANY source....doesn't it.
If someone is singing, some of the vocal goes more in one ear than the other.
Same thing will happen with a stereo mic configuration...it works on any source.
I certainly do get why some people here are tossing the term "stereo source" around....they are basically trying to describe the
type of recording one might do with one kind of sound VS another...but the term "stereo source" is a home rec invention, and taken at face value by someone reading it (like newbs)...it becomes misleading.
There's nothing wrong with saying a grand piano can make for a bigger/wider stereo
recording than a single voice can....but differentiating some live sounds as "stereo sources" and others as "mono sources" has no basis in any acoustics fact or in the science of sound.
The term stereo is purely used to describe a recording or playback system process....and not really how any sound sources behave.
That may all be an insignificant point for some....but then here we seem to pick and choose when to expect correct terminology and definitions and when to allow home rec inventions.
Anyway...people can choose whatever terminology they like, if they have no concern about accurate meaning.
Like when that guy MusicWater said "signal-to-ear" among a bunch of other meaningless audio terms that he invented....
On another note (and nothing to do with the audio terminology discussion above).....below are a couple of audio clips like I said I would post.
This is from a new song I've been working on, still haven't done the final mix, but it's good enough for this purpose. One clip has the lead guitar as the original stereo recording I did, and the other clip has it converted to a pure mono track....everything else is identical in both clips.
As I said earlier...with something like a lead guitar or a vocal or other more narrow focused sources, when using a stereo recording technique, there will never be huge L/R differences or really wide stereo images that are noticible....however, they are still stereo recordings.
With a quick listen....one might think there is no difference in the clips, but when you really listen and compare, it's there.
Like mentioned, even though the lead is in the center, the difference is most noticed in the greater depth/height and 3-D quality of the stereo recording compared to the mono track. The attack and tails bloom out more, and you can feel the lead almost lift vertically in the mix, and become more natural....where the mono version is tighter, smaller and decays quicker in the tails and feels like it sits lower in the track with a slightly drier quality.
These are subtle differences, but in the right production, they could make enough of a difference to a discerning ear...and the better the monitoring, the more obvious the effect of the stereo recording.
Like Bruce Swedien said about his stereo recording -
"These true stereo images add much to the depth and clarity of the final production."
Stereo Lead Clip
Mono Lead Clip
