fat_fleet
Swollen Member
Everyone should have a Twin Reverb in their arsenal! Plus, you could practice electronic repair on the other one if you had a mind to do so.
Pretty much all the convincing I need.
A twin is a great amp. Stellar clean tones with tons of volume. Just bear in mind that if you want crunch you're going to have to have the pedals to get it.
A twin with the right pedals is as good as it gets in terms of a gigging amp.
You can get almost any kind of distortion and crunch in a pedal but a killer clean tone is either there or it isn't
Its defiantly there on a twin
So what's as clean as the Twin but without that much power? I don't think you need that much to have enough headroom for clean.
That's not entirely true. A twin will crunch it's ass off when your turn it up. Check out Johnny Thunders.A twin is a great amp. Stellar clean tones with tons of volume. Just bear in mind that if you want crunch you're going to have to have the pedals to get it.
I'm regret to inform you that your tech is a hack or just lazy. Find a different one. PCBs started showing up in amps in the very early 70s. Maybe late 60s even? They're fixable.
You're pretty much confirming what I think here, though it's not really a crackle and I tried to leave out specific details about the actual problem in the original post to avoid any kind of diagnostic discussion.
But as long as we're here, it's more of a low distorted buzz that's always the same volume (doesn't swell with the note). Sounds almost like a speaker coil rattling away, but I know it's not speaker related. It might not even be audible with louder, more overdriven guitar parts..but I use this amp mostly for cleans and keep it below the point of breaking up. The tech actually replaced a lot of the tone stack and called me saying it was "mostly" fixed, but I went down and plugged in, it just sounded the same to me. I actually had to turn the amp down to point out the sound. I think it would still be a good amp for someone else, but it's just not cutting it for me any more.
Yeah, if you crank the volume all the way up it breaks up a bit, but most people don't have a place or gig where they can use that kind of volume. I was talking about it not having a pre gain for getting crunch at a lower volume.
Ted nugent got a lot of crunch out of twins in the 1970's...
He made a lot of people's ears bleed too
....... .it's more of a low distorted buzz that's always the same volume (doesn't swell with the note). Sounds almost like a speaker coil rattling away, but I know it's not speaker related. It might not even be audible with louder, more overdriven guitar parts......
A cap doesn't have to fail though to be bad, does it? Lots of bad caps in amps still work, they just don't sound good.
