So even newer, very high grade equipment can experience lytic failures
First thing I would do is measure the noise level. Do you have a true RMS voltmeter? If so I'd get 32 150ohm resistors (cheap), stuff them in between pins 2 and 3 of every mic input, source each channel to mic, defeat the eq section, route each channel to the main buss (and ONLY the main buss), turn the trim pots to about 3:00, raise the channel faders to unity, raise the main faders to unity, turn on your true RMS meter to AC volts and measure the voltage level at the unbalanced main output and post it here...convert it db's if you like or we can do that here after we have AC volts RMS value. This will be a measure of the mixer's nominal self noise at unity gain for 32 channels through the mic pre's at a reasonable real-world gain level. Maybe the mixer is already at spec...maybe not.
---When I popped the top off the PSU, I thought I saw a little "brown sludge" on one or two of the caps. ---
A type of hot melt glue to hold the taller radial caps in place.
Remove carefully and you'll be OK.
Sweetbeats, I'm a bit dense sometimes and want to make sure I'm getting this right--what would be the procedure for "stuffing" the resistors between 2 and 3, access the back of each channel XLR in and fix the resistor with a blip of solder to each of the pins? Looks like I can get the resistors for 99cents per 5-pack at Rat Shack and it would be good to know if I'm just asking more from the console than it can give (or less, as it were).
Hey...on that Fader Lube...I was told by both Caig and TASCAM...NOT to use the Fader Lube!!!
The Alps faders do not use any lubricant (like some do).
Caig recommended their D-100 formula...which is the 100% pure cleaning solvent version of their D-5 (only 5%, the rest is propelent).
I just used a Q-Tip dipped in the D-100, then I wiped the carbon tracks, and also the rails...then one pass with a dry Q-Tip, as you don't want to leave too much of a film on there.
The D-100 will provide enough lubrication on it's own. The Fader Lube might be OK at first, but it might gunk up even quicker.
