thexflamesxburn
can someone please specify the differences between the Sennheiser e609 silver and the e906. any feedback would be appreciated. thanks!
soundchaser59 said:The presence filter switch is the only obvious difference......other than the price hike. I dont know the manufacturing specs, but I would guess it's basically the same mic guts.
My suggestion is get the E609, set your tone at your amp instead of relying on the mic switch, then use the money you save to get other mics or other gear. Besides, it's a LOT MORE FUN to tweak your amp than it is to mess with that switch.
that's interesting. i've been doing a lot of research on the topic of the best mic for a guitar amp, and no one has mentioned an nd468, d770, or nd757. why do you mention those?soundchaser59 said:Yeah, I just didn't know if the switch was worth all that extra $$$$$....
I prefer the ND468 or the D770, SM57, or even an old ND757 for the guitar amp..... but I always record at least two together just so I have a choice when I start mixing....
BTW, I'm one of those psyhco's who sets a new tone on the guitar for each song, similar but never exactly the same..... I do have about 10-15 tones written down that are my favorites though...main reason why I dont wanna toy witht he mic. The amp is more fun.
thexflamesxburn said:that's interesting. i've been doing a lot of research on the topic of the best mic for a guitar amp, and no one has mentioned an nd468, d770, or nd757. why do you mention those?
you've convinced me. i'll definitely be picking up an e609 and a nd468 next. thanks a lot!soundchaser59 said:Because I own them and have used them to record my amp. I have recently done side-by-side listening, using all 4 of those mics on the amp at once, then play back the tracks and switch between them to compare while the guitar part plays back.
Someone passed the tips along to me a while back, I tried them all, and now I'm passing the same tip on in the hope that you might someday get to try the extra mics yourself.
All are good amp mics, all are affordable, and each has a slightly different "color" from the others. I've also heard other people's recordings done with those mics and I can say it is definitely easy and possible to get great guitar tracks from any of those mics, all of which are under $150. fullcompass.com has the D770 on sale right now for $56, and it handles a guitar amp quite nicely. Just depends on the particular sound you need to get. All of my songs are similar style, but no one single mic is right for every song I do. I like having the choice. And I managed to get all 4 of those mics for about $400 total (over the last 2 years).
D770 - $55
E609 - $85
ND757 - $120 (replaced it with a ND967, intended for stage vocal but works great on amps!)
ND468 - $140
My brother has the SM57 and SM58 and a D770, among others.....
thexflamesxburn said:well the biggest problem i'm having is hearing palm muting clearly. whenever i palm mute, it gets very muffled and unclear. i'm hoping that the 609 will fix this to a point.
any comments on this?
or technique? No slam, when you record palming it does get a little middy, a little 500 Hz out with a parametric does the trick for meWhoopysnorp said:Are you sure it's not your amp and/or cab?
Whoopysnorp said:However, I have the earlier black version rather than the silver version. I've heard those sound better than the silvers--is that true?
soundchaser59 said:But the 468 was by far the fullest, hottest sounding, and most accurate sounding mic of the three.
Whoopysnorp said:I never found the e609 to be thin-sounding, and I definitely prefer it to the SM57. However, I have the earlier black version rather than the silver version. I've heard those sound better than the silvers--is that true?
thexflamesxburn said:well i KNOW its not my amp. its a mesa boogie dual rectifier half stack, completely using monster gold cables. i'm a pro when it comes to my amp and my guitar (gibson les paul).
