Results 1 to 6 of 6
Thread: What's the difference between Hi-z and Lo-z cables?
  1. #1
    Join Date
    Apr 2004
    Posts
    260
    Thanks
    0
    Rep Power
    472
    Sign in to disable this ad
    What's the difference between hi-z and lo-z cables?
  2. #2
    Join Date
    Apr 2002
    Location
    Framingham, Mass. (near Boston)
    Age
    63
    Posts
    6,832
    Thanks
    0
    Rep Power
    21474859
    As far as I know, none, except that most high-z inputs are 1/4" TS (tip-sleeve) receptacles, and are generally unbalanced. In other words, a high impedence mic is plugged into an instrument jack, and will work when plugged into a guitar amp, etc. It's not the cable that's high-z or low-z, it's the mic's output and the thing it's plugged into. All mics used to be high-z, and some old PA's have only high-z inputs. Characteristically, low-z mics use XLR connectors, and tend to be quieter.-Richie
  3. #3
    Join Date
    Apr 2004
    Posts
    260
    Thanks
    0
    Rep Power
    472
    thank you very much rich! that helps a lot!
  4. #4
    Join Date
    Oct 1999
    Location
    Eagle Winged Palace of the Queen Chinee
    Posts
    1
    Thanks
    33
    Rep Power
    0
    Hi-z cables seem to work better in bondage apps than low-z cables.
    "By the time these guys are finished people will be clamoring for death panels so they can petition for a mercy killing."
    Tiz Walstib
  5. #5
    Join Date
    Jul 2002
    Location
    West Virginia
    Age
    62
    Posts
    124
    Thanks
    0
    Rep Power
    16
    I have two hi-z cables. My dynamic mics work the same with the hi-z and lo-z cables. My local music store owner told me that noise becomes an issue with cables that are 50 feet and longer.
  6. #6
    Join Date
    Sep 2002
    Location
    deep East Texas
    Posts
    2,841
    Thanks
    0
    Rep Power
    887250
    Years ago, when I was running a weekly coffee house venue, I had a couple of low end Shures with high-Z cables. The buzz from the overhead stage lighting drove me nuts, until I looked in the instructions and found out the mics could be rewired for low-Z. I did that, substituted XLR cables for 1/4", and the buzz went away.
    There are other reasons low-Z is better. For one thing, the plugs are a lot more robust and harder to accidentally pull out than high-Z 1/4". For another, whaddya gonna do when you bring your stuff to the gig and all the inputs are low-Z? The length thing is true, also. Fifty feet is pushing it for high-Z. Another is simply that pro equipment is low-Z. You're not going to run your phantom power Neumann on a 1/4" cable.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
