What type of strings would you suggest be better for recording? I'm not wanting a dark gypsy sounding recording, but am limited with the violin being recorded. The most I can do is new strings & microphone.
The strings really have to match the characteristics of the instrument, and in some cases, you may even want to mix a couple different types of strings. I can't give any specific suggestions on violin, as I don't play one, but I can tell you that my Pirastro Aricore strings really brought my plywood Cello to life, IMHO. If you find your violin sounds too edgy and bright, The Aricore strings would be a couple dozen steps back from the edge.
There are others that aren't quite as extreme like Thomastik Dominant (I tried one of those on my Cello after another string broke, which drove me rapidly towards finding better strings because it sounded so much better than the crap strings I had on it) and apparently Pirastro Tonica (which I haven't tried).
Again, though, there's a lot of personal preference involved, and it may take a fair amount of and trial and error to find the right set of strings (or mix of strings), but the first thing I'd do is listen to the tone and see if it sounds too edgy, and if so, experiment with one string (the highest, cheapest string) from Dominant and see if that sounds better, and if it sounds better but doesn't go far enough, try a set of Aricore strings, but if you like the sound as-is on the Dominant string, try a full set of those.
That said, if it sounds good to your ear, it could be that the mic is bringing out some undesirable frequency range. In that case, I'd try a different mic---maybe a ribbon so you can EQ the heck out of it if needed without having any harshness from odd frequency peaks like you'd get with most condensers.
