antispatula
Active member
And really doesn't have much to do with mics, but there is no specific place to put this, and lots of people here seem to know what they're talking about, so I'll ask:
Ok, I need to read the voltage of a signal coming out of my computer.(Soundcards have a -10 db output right? Unbalanced stereo? 1/8") But I have no idea how to use these multimeters.
All I really want to know is which wires to I touch with the 2 leads?
It's a stereo 1/8". So there is the R wire, L wire, and the ground wire.
Which are the ones I touch if I'm measuring the voltage?
And secondly, What setting should I have it on if I'm trying to measure milivolts? There is a setting for both 200m and 2000m. and this is on DCV, right?
The rest below is me ranting and not making sense. What's really important is above.
So NONE of this is making sense. I'm supposed direct current setting right?
So I put the setting at 200m, and I messed around with putting the leads on different wires of the cable. Which ones am I supposed to put the leads on?
Ok so this is what I tried: I'm using a oscillator, a 1kh tone. Since I think soundcards have a -10 db output, and I need a -18 db tone, I put the 1kh at -8, since -10 + -8= -18.
Anyways, I'd measure the vultage, and sometimes the level would increase, going from like .23 to .24 to .25 all the way up to like .4 and it would just keep going. The other time I tested, I would read the tone at like .22 and when I would TURN THE SIGNAL OFF, the level would INVREASE to like .28! Does this make ANY sense?
