billygoatmersh
Which mic do you think is better, the Shure 57, or the 58?
I like the SM57 better.billygoatmersh said:Which mic do you think is better, the Shure 57, or the 58?
The capsule ARE the same on a 57 and 58..... it's the body casing and the distance between the grill/diaphragm on the 58 that causes the slight difference in sound. With the ball end off the 58, it essentially becomes a 57.noisedude said:That's not quite true as I think the 57 has a little foam inside the top? But it's a very good approxiation as long as you're careful - the 58 is not meant to be topless!
I read somewhere on here that they aren't safe without the balls on. I dunno ... I got rid of my 58s a while ago and so only see them in passing now.Blue Bear Sound said:The capsule ARE the same on a 57 and 58..... it's the body casing and the distance between the grill/diaphragm on the 58 that causes the slight difference in sound. With the ball end off the 58, it essentially becomes a 57.
