I use Logic, too. Because we're using Digital Audio Workstations (DAWs, so to speak), I think it's most accurate to say that the SM7b needs a *quiet* preamp, even if it doesn't provide a tremendous amount of gain - the reason is that we can further boost the gain digitally within Logic without adding any additional noise.
If the preamps on the FP10 are noisy, then you'll have an issue -- because you're starting with a lower signal than from a lot of other mics, of course you do need to add more gain to get it where you want it (whether that comes from the preamp or later from software), and if the recorded signal is accompanied by noise, then of course the noise gets boosted, too (and adding the same amount of gain to the noise, which is hopefully lower than the signal, and to the signal, will mathematically result in a less desirable signal/noise ratio). My experience has been that, with regard to noise, it doesn't make much difference whether I record at a low preamp volume and boost digitally or record at a high preamp volume -- I get about the same noise either way. Some preamps do sound different when cranked, because their circuitry starts to overload/clip in pleasant or unpleasant ways, but that's not what I'm talking about here.
Take your SM57 (and/or SM58, and maybe try a couple to make sure you're not using one with a noise issue), which isn't extremely high output, and cut a test track by whispering into it, then add gain in either/both of the ways I mentioned (preamp gain, and or, for instance, the Utilities->Gain plugin) and see how noisy/hissy it is. That'll let you know about where you stand -- the SM7b will has a lower signal than the SM57 (and therefore the same test would result in more noise/hiss), but the difference is not so great as it would be with the condensers you mentioned. *Some* noise/hiss is probably unavoidable without stupidly high end equipment, and unfortunately, I can't provide any guidance here as to how much is OK - hopefully it'll be evident to you.
Another preamp parameter that matters with the SM7b is the input impedance -- does the FP10 have variable input impedance (or a setting where it can be "low" or "high")? Higher impedance to me sounds better with the mic.
