Results 1 to 4 of 4
Thread: Recording Classical Guitar with NT1a
  1. #1
    Join Date
    Nov 2012
    Posts
    267
    Thanks
    0
    Rep Power
    39877
    Sign in to disable this ad
    How would folks go about this?
    the guitar is going to be tracked separately from vocals and accompanying instruments. even with the mic 10 " away I still get tonnes of muddy bass build up which requires drastic high passing (150hz)
    perhaps I'm better off using my RODE M3
    “Some people never go crazy. What truly horrible lives they must lead.”
  2. #2
    Join Date
    Nov 2005
    Location
    NE Indiana
    Age
    35
    Posts
    1,472
    Thanks
    133
    Rep Power
    1552528
    Where do you have the mic pointed? I have used the NT1-a on both nylon and steel stringed acoustics and, IIRC, had the best luck getting a good sound out of each with the mic around 12-14" away placed around the 14th fret and slightly angled away from the soundhole. It took some playing around with though and my room was untreated so it may be a completely different scenario for you. Good luck!
    Intel i5 3.1ghz, Win7 Home Premium 64 bit, 16gb RAM, focusrite saffire pro40, Cubase 7.5, lazy pit bull (gets it from her mother).
  3. #3
    Join Date
    Oct 2005
    Location
    Arlington, VA
    Age
    38
    Posts
    1,613
    Thanks
    355
    Rep Power
    21474849
    ^^^What he said.
    If you are getting tons of muddy bass build up, I am guessing you are mic'ing the sound hole. Don't do that.
    “There is only one good, knowledge, and one evil, ignorance.” - Socrates
  4. #4
    Join Date
    Jan 2006
    Location
    Fremantle, Australia
    Age
    60
    Posts
    5,188
    Thanks
    0
    Rep Power
    11360171
    Room acoustics OK? Heres a picture of a setup when I recorded classical guitar, a picture tells a 1000 words. I had the mics more in front than when I record the usual steel string pop Ballard stuff as it seemed to suit the classical sound. The player is almost centre of the room a little towards one end as the acoustics worked well there.
    If I remember correctly I did not use the distant ribbon or if I did not much, the close the other mics were blended, I did change the blend depending on which guitar was used as one was bright and one was darker. The mics used were a Rode NT1000, a AGK C4000B and 2 x OpenPlanRecording Fathead ribbons.
    Cheers
    Alan
    mike-pratt-blog-1-jpg
Thread Information
Users Browsing this Thread
Similar Threads
  1. Recording Classical Guitar
    By Cyril in forum Newbies
    Last Post: 03-15-2010, 05:57
  2. recording classical guitar
    By daveblue222 in forum Recording Techniques
    Last Post: 04-06-2009, 08:02
  3. Recording classical guitar
    By Almiro in forum Recording Techniques
    Last Post: 05-07-2002, 18:15
  4. Recording Classical guitar
    By joro in forum MP3 Mixing Clinic
    Last Post: 04-08-2002, 20:39
  5. recording classical guitar
    By MGS in forum Recording Techniques
    Last Post: 12-20-2000, 14:58
Posting Permissions
  • You may not post replies
  • You may not edit your posts
