Results 1 to 7 of 7
Thread: Portable Pre
  1. #1
    Join Date
    Apr 2004
    Location
    Agraria, IL
    Age
    56
    Posts
    5,518
    Thanks
    0
    Rep Power
    12084506
    Portable Pre
    Sign in to disable this ad
    Anybody try one of these?
    The fabulous Naiant Mics, perfect for acoustic instruments!
    If you don't have DavidK's CD, you are a loser.
    My tunes. Thanks!
    NB
    DA BEARS!
  2. #2
    Join Date
    Jan 2006
    Location
    satan's taint
    Age
    6
    Posts
    3,378
    Thanks
    2
    Rep Power
    11594459
    nope - I wonder if it would be feasible to add an A/D converter and an SD card for saving recordings? I just went on a trip to Asia, and was thinking it would be awesome to have something like that along with my pair of X-Q's - I could have got all kinds of wild sounds. My regular interface/computer were too big for me to pack.
  3. #3
    Join Date
    Mar 2006
    Location
    Los Angeles
    Age
    35
    Posts
    282
    Thanks
    0
    Rep Power
    100772
    Antichef, I'm planning on a long world wide trip in about a year and a half, and my plan is to bring an M-audio MicroTrack II and a pair of X-Q's. Should be a nice compact way to travel around and get some decent quality field recordings (hopefully )
  4. #4
    Join Date
    Jan 2006
    Location
    satan's taint
    Age
    6
    Posts
    3,378
    Thanks
    2
    Rep Power
    11594459
    looks cool - guess you use 1/4 in. TRS -> XLR cables for the mics?
    The specs look fine - too bad it uses compact flash instead of SD. I think I could put up with that, though.
  5. #5
    Join Date
    Jan 2006
    Location
    satan's taint
    Age
    6
    Posts
    3,378
    Thanks
    2
    Rep Power
    11594459
    Don't mean to practice thread necromancy, but I just noticed that Naiant has the X-P microphone for direct connection to a PC or portable device -- the display unit has what looks like a 3.5mm TRS plug.
    Does anyone know whether these require phantom power? You'd think not, if they're intended to go direct to a PC, but then they are condensers...
  6. #6
    Join Date
    Sep 2005
    Posts
    1,937
    Thanks
    0
    Rep Power
    567414
    Then there's this:
    http://www.engadget.com/2008/07/10/b...ecording-dock/
    Couple it with a 160G Ipod and it could be interesting.
    Yeah I'm an attorney, but everyone needs a day job.
  7. #7
    Join Date
    Jan 2003
    Posts
    11,510
    Thanks
    0
    Rep Power
    0
    Quote Originally Posted by antichef View Post
    I've had that for quite a while, but it used to be on a separate page. Condensers only need high voltage to polarize the capsule, that is, if they aren't electrets which are permanently polarized. Electrets only need a small voltage to drive their FET, which is what a PC mic input is designed to do.
    Anyway, many of my products are designed to run off PC mic power.
    Also, this week I've been staring at the MXL Micmate. I don't like its execution, but it's a clever idea. Other than being too big, my unit seems to have an unacceptable noise. I can't tell if this is a function of a noisy USB ground, noise leaking from its DC converter, a rather unregulated USB +5V feeding the analog supply on the codec, or what, but it's definitely an oscillately-kind of sounding noise.
    So I started thinking about mods, then I just thought maybe I'd build my own. MXL cleverly scratched off the label on the codec, but it wasn't too hard to figure it was one of TI's PCM29xx family. They scratched off the label on their input opamp too, which is silly. C'mon, it's an opamp, no big secret there.
    Anyway, the advantage I would have other than my good looks is my mics don't need more than the 5V supply of the USB bus, so no DC converter is required. That cuts down on potential noise sources right there. Then the usual brew of quality components in a clever package, and there you go.
    I'll do a few things differently. I'll have stereo ins and a headphone out, driven from a high-current opamp (more like the Micmate Pro), with the leads on a pigtail. I won't need a gain control, because the dynamic range of the converter and microphone are defined, so I can simply preset input gain at the required level. I haven't quite figured out headphone level control; it can be done digitally in the PC, but in analogland, I'd need a pot before the output buffer, and that's always a trick when using Neutrik as a form factor. An inline headphone attenuator would work, I guess. What I'd really like is to find a really good 32 ohm full-range speaker and make a mini-monitor for the ultimate in portable monitoring but I don't know if those exist.
    I have to say TI is the cleverest company ever. Well, OK, after Bell Labs. I mean, one chip directly interfaces with analog I/O and USB, with no special drivers required, literally no coding of software or firmware. That's clever. I just hack together datasheet circuits, which is pretty much what MXL has done too.
    Now, to work on the soldering skilzors so I can do 28-SSOP
Thread Information
Users Browsing this Thread
Similar Threads
  1. Portable Rig
    By stevieb in forum Guitars and Basses
    Last Post: 06-23-2008, 07:12
  2. Thank god it's portable
    By billyshuler in forum Don't Fear The Reaper
    Last Post: 10-15-2007, 23:51
  3. Need to set up a portable recording rig...
    By K9SaVeLLi in forum Recording Techniques
    Last Post: 10-17-2005, 03:20
  4. Replies: 12
    Last Post: 04-22-2002, 10:22
  5. portable daw
    By blackmusic in forum Recording Techniques
    Last Post: 03-21-2002, 19:56
Posting Permissions
  • You may not post replies
  • You may not edit your posts
