Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
Thread: Phantompower and/or mixers for my condensator microphone
  1. #1
    Join Date
    Sep 2017
    Posts
    10
    Thanks
    1
    Rep Power
    0
    Question Phantompower and/or mixers for my condensator microphone
    Sign in to disable this ad
    Hi everyone,
    I have just recently bought a condensator microphone from "Aukey".
    It was stronly recommended to also get 48V phantompower with it, so I also ordered such a unit from NEEWER to plug the microphone into.
    However, the signal my computer receives is really low. My microphone volume is set to 100% and I still have to give it up to +25 "Boost" in the Windows option to be even remotely hearable, which is why I'm not satisfied.
    I am by no means any expert on this, so I've kept on reading about the cause and some people seem to have better results with my particular microphone and a mixer. Now the mentioned mixer has no phantom power but something called "PreAmp" I think.
    Can someone give me some insight on this topic if it is better to keep the phantom power or switch to a mixer? Maybe keep both?
    I would really appreciate some advice before I start sending stuff back or before another purchase.
    Thanks to everyone in advance
    EDIT:
    If there are any questions, feel free to ask. I think I'm not very clear on this, but I'm not sure how to give a better explanation
  2. #2
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    32
    Posts
    18,739
    Thanks
    1,074
    Rep Power
    1000000
    Hi,
    Are you taking the line output of your phantom power supply straight into a computer input?
    It sounds that way.
    Any kind of 'pro' mic benefits from a good quality preamplifier, and any powered microphone needs a power supply.
    The two are totally different things but most mixers, pa amplifiers, or audio interfaces will combine both per-channel.
    If you're likely to want to expand and use several microphones at once, this might be a good time to research multi-channel audio interfaces.
    If not, you could get a USB microphone or use your existing mic with an analog mixer into your computer, a USB mixer, or a USB interfaces. ( Other data buses are available. )
    Any mixer or interface would need to have built in phantom power, or would require an external unit like you have now. Most will have it built in.
    Any of those chains will have better quality pre-amplification than your computer's sound card.
    Hope that's helpful.
    ---------- Steenaudio Website ----------
  3. The Following User Says Thank You to Steenamaroo For This Useful Post:
  4. #3
    Join Date
    Sep 2017
    Posts
    10
    Thanks
    1
    Rep Power
    0
    Hi,
    first thank you for the quick response.
    Yes, the Output of the phantom power supply connects directly into my computer input right now.
    I'm not planning on using several microphones as of now or in the near future. If you would not mind, I could post two Amazon links (one of my current microphone and one for the mixer I'm planning to order).
    Hopefully you might be able to tell me if these would work without a "proper" phantom power supply?
    I'm sorry, English is not my first language so I'm kinda struggling with the special vocabulary here
  5. #4
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    32
    Posts
    18,739
    Thanks
    1,074
    Rep Power
    1000000
    Your English is just fine.
    Yes, go ahead and post and links you have.
  6. #5
    Join Date
    Sep 2017
    Posts
    10
    Thanks
    1
    Rep Power
    0
    Condenser Microphone Set so this is the microphone I bought together with this phantom power supplier: Amazon.com: Neewer 1-Channel 48V Phantom Power Supply with Adapter, BONUS+XLR 3 Pin Microphone Cable for Any Condenser Microphone Music Recording Equipment (8 feet): Musical Instruments
    so the performance is really bad in my opinion. The quality of the microphone itself is fine I think but i really need a lot of Boost/Gain from windows to make it remotely hearable. That also results in a lot of noise and it gets too sensitive.
    Now a lot of people suggested to get a mixer like this one here: Amazon.com: BEHRINGER XENYX 502: BEHRINGER: Musical Instruments
    because it features PreAmp or something.
    If I choose to buy the mixer to try it out, would I still need the phantom power supply or can I send it back? Any other advice on what would be wise to make the setup work?
    Thanks to everyone for the help so far
  7. #6
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    32
    Posts
    18,739
    Thanks
    1,074
    Rep Power
    1000000
    Hi again,
    That Behringer will work. From what I've read it has phantom power, although it's not switchable.
    Having said that, it'd be my least favourite solution.
    A Focusrite Solo might be tidier?
    It also doesn't need its own power supply. Just XLR in and USB out.
    It would take your computer sound card out of the equation, which is ideal.
  8. #7
    Join Date
    Feb 2009
    Location
    northampton uk home of Dr Who and Blackstar Amps!
    Posts
    8,418
    Thanks
    1
    Rep Power
    8758214
    Retosi. Don't do anything yet! Is this: AUKEY Condenser Microphone, Bidirectional Condenser Mic with XLR Female to 3.5mm Male Cable, Volume Control and Tripod Stand for Desktop Computers: Amazon.co.uk: Musical Instruments The condenser (aka Capacitor) microphone?
    If so you do not need the phantom power supply* the mic comes with an XLR to 3.5mm stereo jack plug cable. You plug that directly into the laptop's mic jack. You might need to do some settings and level adjustments in Windows Sounds but the results SOULD be quite good. I say 'should' because I have read of a lot of these mics being low output, noisy or not working at all. I had something electrically identical (pretty sure) called the BM-800 and that was remarkably good but it seems for THAT amount of money QC is pretty dire!
    So, try the mic as I suggested and if ok send the phantom power unit back (actually send it anyway, you don't need it at all) . If perchance you have a 'regular' capacitor yes, you need +48V AND a pre amp and, as MrS has said, all best combined in a mixer but NOT the 502! Cheap? Yes but only one mic input and the phantom power is only 15V on some models. The X802 has two mic channels and +48V and I have had one in my bedroom amping up two mics in the garden and it has not been turned off this four years at least!
    However, if you intend the mic for MUSICAL purposes, songs etc you would be far better advised to look at Audio Interfaces. The Alesis i02Express for instance costs little more than a decent small mixer. There are now some good USB mixers but make sure they run 24 bit digital audio.
    *That actually looks identical to one I bought a year ago and if so is a decent unit, not all are! Why do they NEVER give the load specc'?
    Join Date
    Feb 2009
    Location
    Posts
    8,418
    Thanks
    1
    Rep Power
    8758214
    I see you got in while this old brain was still thinking matey!
    Join Date
    Feb 2009
    Location
    Posts
    8,418
    Thanks
    1
    Rep Power
    8758214
    "I'm not planning on using several microphones as of now or in the near future" Ah! But what about the FAR future! Ok, cheap shot but! The mixers and interfaces built with only one mic input are made that way for just one reason, to keep costs very low.
    Now, there are one or two 'one lunged' devices that are otherwise of high quality but not THESE babies! Internal supply rails are usually lower and the general build quality compromised plus, as I said, the 502 has, AFAIK much lower phantom voltage and whilst it is true that a lot of mics DO work down to 12volts, many don't but they ALL work on 48!
    Don't know where you hail from R, but is the phrase 'Ha'poth of tar' familiar to you?
    Join Date
    Aug 2005
    Location
    U.K.
    Age
    32
    Posts
    18,739
    Thanks
    1,074
    Rep Power
    1000000
    There's a link to the mic above, Dave. It's not that one.
Thread Information
Users Browsing this Thread
Similar Threads
  1. Phantompower + power!?
    By perik in forum Microphones
    Last Post: 10-04-2006, 17:54
  2. Replies: 13
    Last Post: 08-30-2006, 11:00
  3. Drum mic overheads - Vocals! Condensator mics.
    By Funky_A in forum Microphones
    Last Post: 04-11-2005, 06:59
  4. PhantomPower and XLR-TELE
    By BillyTheKid in forum Gear Reviews & Questions
    Last Post: 01-20-2005, 12:29
  5. Condensator mic ... to what cost?
    By gastblaster in forum Microphones
    Last Post: 11-22-2003, 22:56
Posting Permissions
  • You may not post replies
  • You may not edit your posts
