RawDepth
I have four ribbon mics and have rarely used them until recently. Now I discover that two of them have no usable level.
I was experimenting today with my kick drum. I tried using the ribbons out in front of the drum at a 45 downward angle. Two of them were so hot that I had to resort to using the line-in jack on the micpre to keep them from peaking the meter, (and with zero preamp gain.) The other two mics had extremely weak signal using the mic-in jack. With the micpre gain turned full up they barely showed any meter nor waveform movement in the DAW. I can hear the mics working, but only slightly above the noise from the pre.
In all instances nothing changed but the mics, the mic/line input choices, and the preamp gain. The preamp works fine with all other mics. The phantom power has never been turned on while using ribbons.
Is there any obvious cause for this low level?
