Results 1 to 8 of 8
Thread: MXL DRK (Direct Recording Kit)
  1. #1
    Join Date
    Sep 2010
    Posts
    6
    Thanks
    0
    Rep Power
    0
    Sign in to disable this ad
    Hi everyone!
    I've got a question: Does anyone have any experience with this mic?
    what i've found thusfar is that it's basically a mxl 990 membrane with MXL 603 electronics combined with internal powersupply(9v batt)
    which makes it pretty handy out in the field, but also might be good for my setup as i still use a line6 sound input with only a 1/4" input (a line6 studio GX to be exact and yes i know.. i should upgrade to a proper I/O and i will, in due time.. i promise:P )
    anyways.. i'd like to know if anyone has any experience with this mic, or whether people have some other suggestions for other internally powered mics which aren't too costly (about 150 bucks maximum) or if there's some experience with other set-ups.. as i've seen something like a XLR to usb converter thingy by MXL (the MXL MicMate)
    or if the Blue Snowball USB mic is any good
    thnx in advance
    ---- edit---
    YES, i KNOW there is another thread called MXL DRK vs MXL 990 or something alike..
    however that thread just didn't talk about the DRK after 2 posts.. it simply shifted to whether the MXL 990was a good mic or not and which other mics were good..
    but i simply want to know if the DRK is worth it's money or not or should i get a preamp+XLR-->1/4"convertor + 30 bucks condensor mic (superlux and behringer have condensor mics for about 30 bucks)
    i only have 100 bucks to use at this moment soo.. and i may upgrade with better mics and equipment in about a year or so.. but i just want to get started already
    ---edit 2-----
    indeed it's a DESKTOP recording kit, NOT DIRECT R K
    my mistake
  2. #2
    Join Date
    Dec 2009
    Location
    New Hampshire Lat/Lng: 42.8129750,-72.0248270
    Posts
    25,770
    Thanks
    58
    Rep Power
    21474870
    Doesn't DRK stand for .... Desktop Recording Kit?
    ♫♪♫ I have a fever and the cure is cowbell ♫♪♫ .......... *LIVE FREE OR DIE* .......... ♫ I'm all ears ♫
    ☼ Mucho Loco Henry Areebah! ☼
    Any mic you buy will be perfectly suited to your needs, until you use it long enough to learn that it's not.
  3. #3
    Join Date
    Sep 2010
    Posts
    6
    Thanks
    0
    Rep Power
    0
    oops yh.. it does.. xD my mistake xD
    somehow i keep confusing those two words.. >.<
    anywayss.. a little update..
    i've increased the available budget by 100 bucks.. soo.. i might be able to get a reasonable I/O with a decent condensor mic.. so now i'll investigate more and other options.. still i would like to know about that DRK.. simply because it's a lot easier to bring that to a bandpractice and hook it up to just any recorder and record a demo and see what it is we caught.. and if i could use that same mic in a studio setting with good results.. even better
    besides that i will get a popscreen, a micstand and a shure PG58 (available over here as a set for 60 euro's.. so.. i'll go get that.. as that stand alone would be 49 euros (yeah go sales! :P )
  4. #4
    Join Date
    Dec 2009
    Location
    Posts
    25,770
    Thanks
    58
    Rep Power
    21474870
    What you should really get to record your band is the Zoom H4n.
  5. #5
    Join Date
    Sep 2010
    Posts
    6
    Thanks
    0
    Rep Power
    0
    oohh that's that lil stereo recorder thingy isn't it?
    yh.. i know i shoud.. xD unfortunately i haven't got the money for such a thing... yet.. xD
    anyways..
    so far so good:
    I'll just update in this topic about what i'm planning to get.. just to keep track and to be able to get some suggestions.
    what i've got now:
    budget: 300
    I/O:
    - M-audio fast track pro (149)
    mics:
    - MXL 990 (80)
    OR
    - MXL DRK (80)
    OR
    - MXL 770 (70)
    OR
    - Superlux CM H 8 BH (70)
    OR
    - Superlux CM H8 CH (90)
    OR
    - MXL 550/551 package (100)
    OR
    -MXL 2006 (100)
    accessories:
    - Popscreen(10)
    - Mic stand (15)
    - cables (10)
    btw what i'm going to use it for would be: vocals, accoustic guitar and ukulele
  6. #6
    Join Date
    May 2006
    Posts
    673
    Thanks
    0
    Rep Power
    488022
    Plus one on the Zoom
    Hi,
    I have a Zoom H4 that I use all the time. I got it for about $200. The H4n is a little more expensive but you should get it even if only for the manual level control on the side of the machine.
    The condensor mics on the Zoom are surprisingly good. When you add mics in the future they will work with it. And you can choose from any phantom powered mics and not limit yourself to battery power.
    The Zoom is also a stereo interface. So once you realize what you're getting it doesn't seem so expensive anymore.
    Thanks,
    Hairy Larry
    Promote your act at Delta Boogie - http://deltaboogie.net
  7. #7
    Join Date
    Sep 2010
    Posts
    6
    Thanks
    0
    Rep Power
    0
    so the zoom H4N can be used instead of the fast track pro?
    hmmm.. that sounds like an interesting option..
    i'll look into it
    thank you
    ---edit---
    it;s a little bit above my budget..
    perhaps in the future i might consider it
  8. #8
    Join Date
    Sep 2010
    Posts
    6
    Thanks
    0
    Rep Power
    0
    UPDATE + review
    Ok Sooo..
    i've been to the stores and got my set-up
    it now consists of an M-audio fast track pro
    and as a mic i bought the MXL DRK (desktop recording kit)
    honestly this is my first better quality mic and i've got to say that i'm really pleasntly surprised but what this little thing is capable of.
    first the versatility: since it has an internal powersource you can simply hook it up on any mixer without phantom.. also you can simply hook it up to any 1/8" input
    it picks up sound pretty good..
    however:when i play guitar accoustically i notice that i have to put the mic really close to get a decent input. Now i can't really compare it to other mics, but that is the only thing that annoys me a little bit..
    for singing however i really like this mic. I can sing softly and it picks it up really clear and easy.
    soo yeah.. i can't compare to other mics.. but for starting out i really like it!
    (btw: yh.. it's a double post.. i know.. but it's been a week since that last post.. so i'm gonna do it anyways :P)
Thread Information
Users Browsing this Thread
Similar Threads
  1. MXL cardioid condenser microphone recording kit
    By Nyce in forum Free Ads for Music/Recording Equipment
    Last Post: 11-27-2006, 23:39
  2. MXL 990 or MXL DRK?
    By Moon2006 in forum Microphones
    Last Post: 01-26-2006, 16:50
  3. MXL Desktop Recording Kit
    By gspraggins in forum Microphones
    Last Post: 11-14-2005, 10:36
  4. the mxl desktop recording kit?
    By oh_the_blood in forum Microphones
    Last Post: 11-12-2005, 09:02
  5. Avlex / Superlux DRK-E4C2 mic kit
    By mikedaul in forum Free Ads for Music/Recording Equipment
    Last Post: 01-12-2004, 11:16
Posting Permissions
  • You may not post replies
  • You may not edit your posts
