+ Reply to Thread
Results 1 to 4 of 4
Thread: MXL 770 or MXL 990?
  1. #1
    jingsta215 is offline Registered User
    Join Date
    Mar 2011
    Posts
    9
    Rep Power
    0
    MXL 770 or MXL 990?
    Sign in to disable this ad
    which mic should i buy for my home recording studio?
    the MXL 990 is 60 bux, and the MXL 770 is 80 bux
  2. #2
    Cosmic is offline Dedicated Member
    Join Date
    Oct 2004
    Location
    Washington DC
    Posts
    444
    Rep Power
    96112
    The first thing you should ask yourself is:
    Is my room acoustically good enough that I can tell any difference between any condenser mic below or around $100?
    Dynamics are less sensitive than condensers, and thus will be more forgiving in a poor environment.
    If your acoustics are bad or less than ideal, and you want a cheap condenser, just buy the less-expensive one and save the money.
    CC.
  3. #3
    moresound's Avatar
    moresound is offline Loud Sun Studios
    Join Date
    Dec 2009
    Location
    New Hampshire Lat/Lng: 42.8129750,-72.0248270
    Age
    99
    Posts
    22,699
    Rep Power
    21474862
    Neither! Go with the MXL V67g and you'll be a bit more happier.
    ♫♪♫ I have a fever and the cure is cowbell ♫♪♫ .......... *LIVE FREE OR DIE* .......... ♫ I'm all ears ♫
    ☼ Mucho Loco Henry Areebah! ☼
    Any mic you buy will be perfectly suited to your needs, until you use it long enough to learn that it's not.
  4. #4
    Join Date
    Oct 2004
    Location
    Washington DC
    Posts
    444
    Rep Power
    96112
    I have the V67. They are a bit noisy but that one can live with.
    If you plan any female vocals with this, it can have a nasty 'rip' at about 3000-4000hz depending on mic angle and delivery.
    Overall, I still maintain that a bad room makes most of the cheap condenser decisions moot. 57 and 58 will come out winners in many instances because you sing/play more closely to them and don't hear the lousy acoustics quite so much.
    I did a vocal with a 58 in my closet which sounded better than done with a Neumann 147 in the same space. Why? Presence and quiet from the close singing.
    The Neumann had a lot of detail but also took in everything else. So will the MLX mics. It's the nature of them.
    CC.
+ Reply to Thread
Thread Information
Users Browsing this Thread
Similar Threads
  1. FS: MXL V67G, MXL 990, MXL 603, Morley Classic Wah
    By Harlequin Man in forum Free Ads for Music/Recording Equipment
    Last Post: 01-03-2008, 16:55
  2. MXL 990/MXL 991 Package any opinions
    By gdavi1 in forum Microphones
    Last Post: 12-03-2007, 17:41
  3. Mic shootout - MXL 603 vs MXL 770
    By hairylarry in forum Microphones
    Last Post: 12-26-2006, 13:41
  4. MXL 2001 vs. MXL 990 for vocals/amps
    By SMX_Dizzy in forum Microphones
    Last Post: 08-13-2006, 23:42
  5. Replies: 13
    Last Post: 06-04-2004, 19:33
Posting Permissions
  • You may not post replies
  • You may not edit your posts
GearFest Mixing Contest
Biggest Ever Audio Mixing Contest is ON!
