Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
Thread: Microphone for distant voice
  1. #1
    Join Date
    Apr 2017
    Posts
    7
    Thanks
    1
    Rep Power
    0
    Question Microphone for distant voice
    Sign in to disable this ad
    Hi, i'm a little lost about microphones,
    i'm searching a new microphone for recording my voice, but the microphone will be 1 meter away from me, i thought about a supercardioid shotgun microphone, the kind of microphone used on camera.
    But i have a feeling it's a little bit overkill just for static voice recording. Is there any alternative microphone for this use? Am i missing something ? (btw i have a budget around 100€).
    thank you for your time
    EDIT:
    Quote Originally Posted by arcaxis View Post
    Why does the mic need to be 1 meter away (what are you doing)?
    In fact it's more between 0.5 and 1 meter and yes it's for video and comfort.
    Quote Originally Posted by mixsit
    'Out side, inside, do you control the environment- therefor the variables..?
    Maybe headworn mic and visual and sound quality don't matter.
    It's inside, i control the environment (some background white noise is not a problem, if it's not too loud)
    The visual don't matter, the sound quality does (it's only for voice) and like i said the mic must be distant from me.
    Also, i will cut sound under a certain number of decibel.
    And i have a sound card with XLR (+ 48v)
  2. #2
    Join Date
    Mar 2001
    Location
    ArizonaMaybe
    Age
    67
    Posts
    9,235
    Thanks
    133
    Rep Power
    9366459
    The results will depend hugely on the situation, and how much and how well you can control he following;
    1 The level of background noise vs how loud 'the voice' is -at the mic- And/or decreasing the distance to the mic is another way to get to the same place.
    2 Having sound deadening panels or treatment to a) reduce the unwanted noise in the room competing with the voice, or b) blocking it from getting to the mic
    3 Highly directional mics -But #1 and 2 are more important.
    Short of full out shotgun mics, look to any decent hyper cardioid mic.
    You might want something flatter (you didn't give enough info), but a used OM5 for example.
    http://www.audixusa.com/docs_12/spec...M5_V3_0516.pdf
    That's about as tight as you can find.
    Placebo stomps 96k ....... Recent projects
    Ray Catfish Copeland 'Got Love Jim Goodman 'Southern Steel
  3. #3
    Join Date
    Apr 2017
    Posts
    7
    Thanks
    1
    Rep Power
    0
    I can give more info what do you need?
  4. #4
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    69
    Posts
    4,096
    Thanks
    1
    Rep Power
    10103961
    Why does the mic need to be 1 meter away (what are you doing)? Or does it just need to be out of view if the audio is for a video?
    Mark.......
  5. #5
    Join Date
    Mar 2001
    Location
    ArizonaMaybe
    Age
    67
    Posts
    9,235
    Thanks
    133
    Rep Power
    9366459
    Yeah. Stuff like that. 'Out side, inside, do you control the environment- therefor the variables..?
  6. #6
    Join Date
    Dec 2013
    Location
    essex
    Posts
    1,562
    Thanks
    5
    Rep Power
    2764033
    It's all about wanted to unwanted sound. A metre away is fine, if the room is big, the room is quiet and immediately behind you is not something reflective or noisy. The trouble comes in that the polar pattern of the microphone, no matter how narrow, always picks up other stuff too - people in the background, a drummer, or just reflections from the rear wall. Only you will know if your circumstances mean it's going to work. If you need to do this in an open field, with no wind, no natural or man made noises at all - so silence pretty much, then 1m away will sound pretty natural. Try it in a night club with a sound system and loads of people all shouting, then it will fail badly.
    Remember that before the age of radio mics in TV studios world wide, mics were on booms, and rarely were they any tighter than a hyper-cardioid - but with accurate aiming and careful control were fine at a metre or even more away.
  7. #7
    Join Date
    Apr 2017
    Posts
    7
    Thanks
    1
    Rep Power
    0
  8. #8
    Join Date
    Mar 2001
    Location
    ArizonaMaybe
    Age
    67
    Posts
    9,235
    Thanks
    133
    Rep Power
    9366459
    Quote Originally Posted by Miawrr View Post
    Very good, and totally doable. Looks like you're good to go then.
    add.. BTW, control #1 and #2, you don't have to be restricted to specialty (super narrow) mics.
  9. The Following User Says Thank You to mixsit For This Useful Post:
  10. #9
    Join Date
    Apr 2017
    Posts
    7
    Thanks
    1
    Rep Power
    0
    Thank you, i'm not asking for high end microphone anyway
    What's your suggestion?
  11. #10
    Join Date
    Dec 2002
    Location
    Massachusetts
    Age
    69
    Posts
    4,096
    Thanks
    1
    Rep Power
    10103961
    Before suggestions for the mic.........
    What will you be connecting the mic into? Direct into computer (3,5mm mic jack), mixer with XLR connectors & phantom power, or USB interface?
    Mark.......
Thread Information
Users Browsing this Thread
Similar Threads
  1. Microphone for Voice-overs
    By ecroow in forum Microphones
    Last Post: 08-31-2016, 10:54
  2. What Microphone do they use in The Voice?
    By flight674 in forum Microphones
    Last Post: 05-03-2016, 08:41
  3. Which microphone should I get for this type of voice here?
    By mdvuh in forum Recording Techniques
    Last Post: 01-06-2014, 19:20
  4. Voice VS microphone
    By snakeyez in forum Microphones
    Last Post: 10-31-2007, 09:11
  5. Anti-reverb? voice that sounds distant
    By jackstpaul in forum Cool Edit Pro / Adobe Audition Forum
    Last Post: 06-07-2004, 03:54
Posting Permissions
  • You may not post replies
  • You may not edit your posts
