Im thinking between Blue Bird microphone and Audio Tehnica at4040 for recording rap and hip hop vocals.
Bluebird:
Transducer Pressure Gradient Condenser
Polar Pattern Cardioid
Frequency Response 20Hz to 20kHz
Dynamic Range (Typical) 130dB
Signal-to-Noise Ratio Not more than 7.5dB
Maximum Input Sound Level (0.5% THD into 2.5k ohms): 12dBV = 3.1V
Power Requirements +48V Phantom Power (+35V min.)
Output Impedance Not less than 1k ohms
Output Connectors 3-pin XLR
Audio Tehnica at4040:
Transducer Condenser
Frequency Response 20 Hz - 20 kHz
Dynamic Range (Typical) 133 dB, (1 kHz at Maximum SPL)
Signal-to-Noise Ratio 82 dB, (1 kHz at 1 Pa)
Maximum Input Sound Level 145 dB SPL, (1 kHz at 1% T.H.D.)
Power Requirements Phantom, 48v
Output Impedance 100 Ohms
Output Connectors XLR-3M Type
What do you think ?
Bluebird:
What do you think ?
