Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Mic Software Preamp
  1. #1
    Join Date
    Nov 2005
    Posts
    6
    Thanks
    0
    Rep Power
    0
    Mic Software Preamp
    Sign in to disable this ad
    Is there any software out there that acts as a mic preamp without any hardware? if someone could help me it would much be appreciated!
    thanx.
  2. #2
    Join Date
    Dec 2004
    Location
    Sunnyvale, CA
    Age
    41
    Posts
    5,743
    Thanks
    0
    Rep Power
    3408650
    Short answer: no.
    Long answer: absolutely not.
    A mic preamp converts a very weak audio signal into a signal strong enough for the encoders in your audio interface to pick it up in a usable way. Yes, you -could- boost it afterwards in software, but the result would be an extremely high level of noise, as the amount of signal coming into your interface from a mic would be very small relative to the amount of electrical noise inherent in the audio interface itself.
    Decent preamps start at around $25 per channel. Don't sweat it.
    Quote Originally Posted by Obi-Wan
    If you mod me down, I will only grow stronger.
  3. #3
    Join Date
    Nov 2005
    Posts
    6
    Thanks
    0
    Rep Power
    0
    thanx for ur help
  4. #4
    Join Date
    Jan 2006
    Posts
    9
    Thanks
    0
    Rep Power
    0
    Just an added thought....
    Well, maybe there's more that can be said. I think the answer to your
    question depends on why you're asking and what you're going to do with
    what you record. Not everybody here is trying to make the next
    "Rubber Soul" or "The Wall" in their den recording studio.
    If your purpose is recording as some kind of tool, that is documentation of
    some kind -- perhaps of a simpler sound source than a whole band -- and
    you don't need the pre-amp for mic power, then the computer you're
    reading this on might be "enough" to take the analog signal and serve the
    purpose. There are some software applications that will "touch up" the
    signal and might meet your needs.
    Short story: When I began selling musical instruments over the Internet,
    I needed sound files for my customers. I have a small studio from the
    1970s, but the years have caught up with it.
    I'm about to purchase new equipment, but for the last year I've used a
    dynamic mic into my computer's soundcard into "Audacity" freeware.
    In that application I use "plug-in" editors to adjust the sound. The ones
    I use are "normalize," which places the signal at an optimal level, doing
    much of what a pre-amp does; "equalize," removing unwanted excesses
    like fingernail squeek; and "reverb" just a touch to relax things.
    Are these studio-quality recordings? No.
    Do they meet the need? Absolutely.
    My customers have repeatedly commented on how the instrument
    they received sounds just like the recording they listened to.
    Given the nature of your question, I hope it's okay to add these comments.
    Good luck.....
  5. #5
    Join Date
    Jan 2003
    Posts
    11,510
    Thanks
    0
    Rep Power
    0
    A mic preamp does a few different things:
    - provides proper input impedance for the microphone
    - converts the balanced microphone signal to unbalanced, and proper grounding and isolation for the signal
    - provides phantom power for mics that need it
    - amplifies the signal, without excessive and unpleasant distortion or noise
    - sometimes, adds "color", "character", or if you please, pleasant distortion.
    Now, back to the question. There has to be an analog component to an A/D converter, because the signal starts in the analog world. It should be perfectly possible to design a converter that does the unbalancing and obviates the need for amplification. "Color", etc. can be added by software, whether or not that's the same box of crayons as analog is a larger question than this thread.
    Are converters designed this way right now? For the most part, no, because the demand has been for converters to interface with existing microphone preamps. But there are already a few mics with internal converters, I suspect that will become a lot more common in the future, as having conversion right off the capsule would simplify a lot of issues with mics and mic preamps.
    If you want good quality recordings without a bunch of extra gear, there are two paths you can travel today: USB microphones, like the Blue Snowball, or regular ol' studio-quality analog mics with all-in-one interfaces that have bundled preamps, converters, and soundcard. Neither option is particularly expensive.
    You'll find that either of those is a superior solution to using a studio-quality mic with consumer-grade soundcards and their onboard preamps and converters, which are typically inferior in one or many of the aspects I listed above.
  6. #6
    Join Date
    Jun 2004
    Location
    Novato, CA
    Posts
    3,808
    Thanks
    0
    Rep Power
    780347
    Quote Originally Posted by Ken in Dallas
    What you are doing here is using the preamp built into your soundcard. It is NOT done in software. It is still done in hardware. All you are quibbling about is the quality of the preamp in your soundcard.
    Sheesh. I would strongly suggest that you do some research around here before investing in new equipment.
    The fact that no one understands you doesn't mean you're an artist...
  7. #7
    Join Date
    Aug 2001
    Location
    Chicago, IL
    Age
    47
    Posts
    11,823
    Thanks
    0
    Rep Power
    0
    I don't have any $$ for accoustic treatment.
    I was wondering if there was some sort of software / plugin (that could serve as accoustic treatment or sound proofing) I could use instead (?)
    Thanks.
  8. #8
    Join Date
    Dec 2004
    Location
    Unicorn Heaven
    Age
    54
    Posts
    15,602
    Thanks
    9
    Rep Power
    21474865
    Quote Originally Posted by chessrock
    Thanks.
    Yes.............
    Honey Badger is badass...he don't give a shit.
  9. #9
    Join Date
    Jan 2006
    Posts
    545
    Thanks
    0
    Rep Power
    12239
    its called unverb..its the latest studio craze
    [AKA PINACHI]
    Hipnotizing reels
  10. #10
    Join Date
    Oct 1999
    Age
    40
    Posts
    1,391
    Thanks
    0
    Rep Power
    216084
    There's also a new plug-in called "Slapback echo remover" and "standing-waves remover"
    I'm still waiting for the "Tony Rice Flatpicking Plugin"
Thread Information
Users Browsing this Thread
Similar Threads
  1. Dongle Crack for SX 2
    By Hector_Osbert in forum Steinberg / Cubase User Forum
    Last Post: 05-27-2009, 15:10
  2. Help: Mic Decisions and My Trip to Guitar Center
    By JohnnyMan in forum Microphones
    Last Post: 04-16-2006, 22:38
  3. Replies: 15
    Last Post: 05-13-2005, 21:22
Posting Permissions
  • You may not post replies
  • You may not edit your posts
