+ Reply to Thread
Results 1 to 3 of 3
Thread: Klaus Heyne on modification of the Neumann u87
  1. #1
    BigRay's Avatar
    BigRay is offline I hate jambands.
    Join Date
    Oct 2005
    Location
    Southeastern NC. No more Krauts and Bad music.
    Age
    35
    Posts
    1,876
    Rep Power
    7392
    Sign in to disable this ad
    Got this email from him today. Very interesting to me.
    Teddy
    There is more than one approach to modifying and improving the overall
    performance of a U87.
    The ³Innertube² approach of replacing the complete impedance converter
    and mic amp with a new, tube driven unit that readily connects to the
    original capsule head was already mentioned. Another approach would be
    to stay in the solid-state domain and optimize the mic from there.
    A short bit of background info may be in order, to better understand
    the ³why?² of modifying a mic that sells very well and generally seems
    well-enough liked in its stock configuration.
    During the 1970s and still to date, the U87 and other German and
    Austrian condenser mics were tailored to a highly specialized but very
    lucrative market- the German Broadcast System.
    The broadcasters¹ ³brown book² (spec book) mandated design elements any
    bidder for a purchase contract for many thousands of mics needed to
    fulfill (and eagerly fulfilled them), sonic consequences to all other
    applications be damned.
    Some of the U87¹s design parameters were actual quite reasonable in the
    broadcast environment, even if they were detrimental to other
    applications, like studio recording:
    High-end shelving of -4dB @16khz, (the pilot tone of stereo broadcasts
    was transmitted at 19k, so any interference by a mic transmitting
    beyond 16k needed to be avoided). stark low end attenuation, overall gain
    suppression (to conform to the gain chain established many years earlier)
    heavy RF-choking (self evident in broadcast environments) and so on,
    all needed to be addressed, so that Neumann was able to sell this and
    other models to its biggest customer.
    The modifier¹s job then would be to eliminate these curtailments,
    rebalance the frequency response, avoid excessive headroom limitations after
    removing the global and frequency specific feedback loops (which are
    responsible for the infamous mid range ³honk² of the mic), and fine tune
    a capsule which, as good as it is, has a wide enough manufacturing
    tolerance resulting in a wide variety of timbres.
    This kind of work costs according to the modifier¹s ultimate success to
    transform the mic into an object of sexual desire, his reputation,
    warranty, servide-friendliness.
    The modifications can be applied equally successful to the old (U87i)
    and new (U87Ai) model.
    Best regards,
    Klaus Heyne
    Quote:
    Would you be able to tell us what modifications are available for an
    87, and what the pros/cons of each are?
    Quote:
    I am interested in what is done when what I would think is a perfectly
    good mic (the 87) is modded? I am not meaning debate who is doing the
    mod, or why, or whatever, but what would one change and why?
    I know very little about what modifications are available from others
    for the U87.
    I know the route that Stephen Paul, my late, long time, and respected
    competitor took: he concentrated on diaphragm design and replacement.
    I also understand, (though never personally tried) the Innertube
    philosophy of replacing the FET guts of the impedance converter's
    (solid-state) electronic processor with a tube, while leaving the capsule alone
    My fundamental approach to modifying a U87 is this:
    I want to hear as much of the brilliant, ingenius K67/87 capsule
    design's sex appeal with the least amount of loss or artifacts from the
    electronic processing.
    For those unfamiliar with the history of the U87:
    This model used to be the bread and butter mic of the Neumann company-
    more than 90,000 of these were made so far, and counting.
    Unfortunately, anything and everything the German Broadcasting system
    asked for, Neumann incorporated in the electronic processing of this
    model - the good, the bad and the ugly. But then- who would argue with the
    sales department?
    In the non-broadcasting environment of today, (and these days even in
    the broadcasting environment!) few of the Broadcast Brown Book specs of
    the 1960s are useful:
    High amount of negative feedback, both, for overall gain and for eq,
    severe roll-off in the bass, 4dB down at 16k, and so on, all attribute to
    the (in)famous "honk" of the mic when the same capsule used in the much
    gentler processing of the SM69 and M269, or U67 tube models sounds so
    much more musical and engaging.
    So what do I do?
    I gut the existing audio processing, connect the capsule with the
    fewest necessary components in the simplest, most elegant way to the output
    of the mic, replace the remaining components necessary with those of
    the highest audio quality, regardless of cost, my ears can discriminate,
    fine tune the capsule's parameters to the intended use, and enjoy the
    ensuing musicality and sex appeal out of a mic that is not particularly
    known for its musical sensuality.
    On occasion, I will specialize the U87 for certain applications-
    Scoring, ADR, foley, voice talent, specific vocalists, instruments or
    ensembles, but overall the same philosophy is always applied.
    This work is only successful if I have good capsule material to start
    with- either a well selected new K67/87, or a used one, where at least
    one of the sides has musical balance and somewhat of a personality that
    draws me in.
    These are the (to me) obvious advantages of modifying further a mic
    that is hugely successful in the first place. There is one downside: I
    lose a bit of head room when I remove global negative feedback from the
    system- in the order of 6dB; however, I regain 3-4dB by using FETs with a
    very high headroom. (Not that U87s are known for their huge head room
    in the first place)
    If all of this sounds rather unscientific- it is. I am not fond of
    quoting specs or using measuring equipment to monitor my progress (when was
    the last time an ELA M251 has changed hands for $18k with a frequency
    plot attached?)
    Instead, I listen, judge, adjust, listen, judge, adjust, sometimes all
    day long, sometimes for days.
    May God grant me a few more years of good hearing.
    Kind regards,
    Klaus Heyne
    [IMG]http://www.capitolflags.com/images/confederate-rebel-small.gif[/IMG]
  2. #2
    Giganova's Avatar
    Giganova is offline gimmi your mic!
    Join Date
    May 2002
    Location
    Washington DC
    Posts
    1,197
    Rep Power
    320
    Great post!
    Does Klaus know that you publicly post his emails?? (not sure how many laws you just broke)
  3. #3
    BigRay's Avatar
    Join Date
    Oct 2005
    Location
    Age
    35
    Posts
    1,876
    Rep Power
    7392
    Quote Originally Posted by Giganova
    Great post!
    It wasnt actually an email that he created just for me, but rather a compilation of several posts of his on prosoundweb, compiled in email format. prosoundweb is a public forum.
+ Reply to Thread
Thread Information
Users Browsing this Thread
Similar Threads
  1. "ANNOY-MAN" Microphone...
    By kidvybes in forum Microphones
    Last Post: 02-03-2005, 06:58
  2. 60s Neumann U87 usefull for modern pop/rock ?
    By Jaguar in forum Microphones
    Last Post: 06-25-2004, 20:17
  3. Metal Vocals and a neumann U87
    By mr. torture in forum Microphones
    Last Post: 05-10-2004, 06:58
  4. Neumann TLM-103 or AKG Solid Tube?
    By caretaker9 in forum Microphones
    Last Post: 07-08-2002, 09:18
  5. Neumann U89 or U87
    By j0nas in forum Microphones
    Last Post: 01-13-2002, 09:10
Posting Permissions
  • You may not post replies
  • You may not edit your posts
HomeRecording Newsletter
Subscribe to HomeRecording's Official Newsletter!
