Forenzikks
Real quick for rap vocals is a 57 or 58 better i ve read all the debates but never saw a straight up yes or no for which one would suit rap vocals.thanks
Forenzikks said:Real quick for rap vocals is a 57 or 58 better i ve read all the debates but never saw a straight up yes or no for which one would suit rap vocals.thanks
DJL said:That is because there is no straight up answer. The answer is "it depends". Try them both and use the one you think is best.
DKMurphPr said:The 57 and 58 are *nearly* identical, not exactly the same. Take a look at the frequency response graphs of each mic in the respective user guides.
coloradojay said:Damn DJL, you beat me to the time-honored "Try them both" by one minute!
Were talking about rap vocals, you are concerned so much with losing high end, and 99% of the time the vocal is a monotone without falsetto, and extra high end will make it more harsh even if its needed. Besides you can purchse extra balls for the mic and remove the foam effectively giving it the same response.
Rap vocalists also tend to get thier lips on the mics so a ball end will be a little less gross, and the 57 will be honky with a vocal that close.
