I have an Amphenol type, 91-MC3M, 3-pin screw-on connector that i need to connect to an XLR or a 1/4" male guitar cable. Need steps on where the copper wires go and how.
Custom cable is your answer.
look here.http://www.oaktreeent.com/Vintage_St...one_Cables.htm
Or if your extra smart you could make one your self.
F.S.
Where is Darwin when you need him?
When you said "you wanted to connect it to an XLR OR 1/4" male", I am assuming you are talking "balanced" which would be a 1/4" TRS. T (on the TRS) would go to pin #2 on the Amphenol/XLR connector. R (on the TRS) goes to pin #3, and the S (sleeve) which is the ground/drain/braided wire goes to pin #1
If you are going "un balanced" you use a 1/4" TS plug and lift (do not connect the wire) that comes from pin #3
Chance Pataki
The Musicians Workshop
musicians.workshop@gte.net
http://www.the-musicians-workshop.com
I followed your instructions.
My situation is the XLR TRS end is been cut off.
I installed a new one and it hums.
Originally it was TRS Phono type.
Now its XLR and humming.
When the big ground is not attached I get a slightly less hum.
The cord hums even when not attached to the mic.
I don't quite have $65 for a cord + shipping + duty.
How may I go about D.I.Y?
Should I try for the original TRS end?
Thanks!
You may have a bad connection at the Amphenol end, or a bad cable. You need to check the continuity of each wire in the cable. Do you have a meter of some kind (volt/ohm meter) or some type of continuity tester?
Even without this, the first thing you could do is resolder the Amphneol connections, or even better, cut a few inches of the cable off and remake the connections. Cables tend to break at the entrance to the connector where the most bending and stress is placed on them.
I'm going through a difficult period - it's called life
Bookmarks
