Hi there,
Recently I have been having a problem with my SM7B Microphone where the vocal input becomes staticy- Here is a recording of the issue . The Mic would start up normal then switch to the static several minutes into use. Unplugging then re-plugging the pre-amp seems to fix the issue for a short duration before it returns to a staticy state.
My Set Up is as follows:
Pre-Amp - M-Audio - M-Track II
FetHead- Shop - tritonaudio
SM7B - SM7B Vocal Microphone | Shure Americas
Any suggestion on possible cause or fix would be much appreciated.
Thank you so much for your time.
